catalyst 9200 stack issue
M Mohammed
Level 3
Level 3
Hi All,
i have cisco catalyst 9200, a stack of 5, which reboots every often. please see below in the output for the changes to the link OK its 8 and 6. could that be a possibility for the reboot and why is that different any advise please?
Sw#/Port# Port Status Neighbor Cable Length Link OK Link Active Sync OK #Changes to LinkOK In Loopback
1/1 OK 5 100cm Yes Yes Yes 1 No
1/2 OK 2 50cm Yes Yes Yes 8 No
2/1 OK 1 50cm Yes Yes Yes 6 No
2/2 OK 3 50cm Yes Yes Yes 1 No
3/1 OK 2 50cm Yes Yes Yes 1 No
3/2 OK 4 50cm Yes Yes Yes 1 No
4/1 OK 3 50cm Yes Yes Yes 1 No
4/2 OK 5 50cm Yes Yes Yes 1 No
5/1 OK 4 50cm Yes Yes Yes 1 No
5/2 OK 1 100cm Yes Yes Yes 1 No
Kind regards
Mohammed
15 Replies 15
Leo Laohoo
What firmware is the stack running on?
hi @Leo Laohoo
Switch Ports Model SW Version SW Image Mode
* 1 52 C9200L-48P-4G 16.11.1 CAT9K_LITE_IOSXE INSTALL
2 52 C9200L-48P-4G 16.11.1 CAT9K_LITE_IOSXE INSTALL
3 52 C9200L-48P-4G 16.11.1 CAT9K_LITE_IOSXE INSTALL
4 52 C9200L-48P-4G 16.11.1 CAT9K_LITE_IOSXE INSTALL
5 52 C9200L-48P-4G 16.11.1 CAT9K_LITE_IOSXE INSTALL
i would advise to cross check all the stackcables and they are intact.
i may see some kind of bug reported like this, not able to find one. once they re-fix the stack cable, it was stable later.
BB
16.11.1?
I seriously recommend upgrading the firmware of the stack.
16.11.1 has several serious issues with stacking.
Post the complete output to the command "sh platform soft mount switch <SWITCH NUMBER> r0 | i ^tmpfs.*tmp | e /tmp/".
Normal value is <5%. If any of the switch has a value of >70% then this is a well-known bug: CSCvp73396
And now here's the kicker: If any member of the stack has crashed and recovered, they might be hitting a 2nd bug - CSCvp03655.
@Leo Laohoo
did run the command but found not output
WIN-3FL-SW1#sh platform software mount switch 1 R0 | i ^tmpfs.*tmp | e /tmp/
WIN-3FL-SW1#
any other output you think
@balaji.bandi  thanks
since you did not find any output as expected.
i still stand on same point, check the Physical cables, and upgrade to latest suggest code .
BB
@balaji.bandi
sure, i will try as you recommend, will find the downtime and once done let you know the outcome
regards
Mohammed
Pick one of the switches that "rebooted" recently.
Post the complete output to the command "dir crashinfo-<SWITCH NUMBER>:".
Hi @Leo Laohoo Please see below
WIN-3FL-SW1#dir crashinfo-1
%Error opening flash:/crashinfo-1 (No such file or directory)
WIN-3FL-SW1#dir crashinfo-2
%Error opening flash:/crashinfo-2 (No such file or directory)
Syntax is incorrect.
It should be "dir crashinfo-X:" (notice the ":" at the end).
Hi, @Leo Laohoo
Please see below the information for CRASHINFO
SW1#dir crashinfo-1:
Directory of crashinfo:/
11 -rw- 0 Jan 1 1970 00:00:56 +00:00 koops.dat
36641 drwx 32768 Mar 11 2020 15:24:13 +00:00 tracelogs
30 -rw- 25699930 Nov 6 2019 23:15:57 +00:00 system-report_1_20191106-231545-UTC.tar.gz
12 -rw- 1197256 Aug 5 2019 11:23:38 +00:00 WIN-3FL-SW1_1_RP_0_trace_archive_0-20190805-112335.tar.gz
13 -rw- 1211417 Aug 5 2019 11:23:41 +00:00 WIN-3FL-SW1_1_RP_0_trace_archive_2-20190805-112339.tar.gz
15 -rw- 372311 Aug 26 2019 05:01:49 +00:00 WIN-3FL-SW1_1_RP_0_trace_archive_7-20190826-050148.tar.gz
14 -rw- 1257070 Aug 6 2019 00:58:38 +00:00 WIN-3FL-SW1_1_RP_0_trace_archive_5-20190806-005832.tar.gz
16 -rw- 385857 Aug 26 2019 05:01:51 +00:00 WIN-3FL-SW1_1_RP_0_trace_archive_9-20190826-050150.tar.gz
17 -rw- 392361 Sep 4 2019 05:56:24 +00:00 WIN-3FL-SW1_1_RP_0_trace_archive_14-20190904-055622.tar.gz
18 -rw- 412411 Sep 12 2019 22:54:03 +00:00 WIN-3FL-SW1_1_RP_0_trace_archive_16-20190912-225401.tar.gz
19 -rw- 421996 Sep 12 2019 22:54:03 +00:00 WIN-3FL-SW1_1_RP_0_trace_archive_18-20190912-225401.tar.gz
20 -rw- 355484 Sep 14 2019 22:54:06 +00:00 WIN-3FL-SW1_1_RP_0_trace_archive_20-20190914-225405.tar.gz
21 -rw- 408611 Sep 14 2019 22:54:22 +00:00 WIN-3FL-SW1_1_RP_0_trace_archive_23-20190914-225421.tar.gz
22 -rw- 474900 Sep 14 2019 22:58:26 +00:00 WIN-3FL-SW1_1_RP_0_trace_archive_24-20190914-225825.tar.gz
23 -rw- 400298 Sep 21 2019 20:58:36 +00:00 WIN-3FL-SW1_1_RP_0_trace_archive_26-20190921-205832.tar.gz
24 -rw- 1526472 Sep 22 2019 09:02:59 +00:00 WIN-3FL-SW1_1_RP_0_trace_archive_1-20190922-090252.tar.gz
25 -rw- 297003 Sep 28 2019 00:18:35 +00:00 WIN-3FL-SW1_1_RP_0_trace_archive_4-20190928-001833.tar.gz
26 -rw- 319362 Oct 1 2019 13:26:54 +00:00 WIN-3FL-SW1_1_RP_0_trace_archive_2-20191001-132651.tar.gz
27 -rw- 1339770 Oct 3 2019 04:42:32 +00:00 WIN-3FL-SW1_1_RP_0_trace_archive_0-20191003-044227.tar.gz
28 -rw- 295564 Oct 5 2019 08:11:33 +00:00 WIN-3FL-SW1_1_RP_0_trace_archive_1-20191005-081130.tar.gz
29 -rw- 354224 Oct 29 2019 21:23:52 +00:00 WIN-3FL-SW1_1_RP_0_trace_archive_0-20191029-212348.tar.gz
31 -rw- 309854 Nov 6 2019 23:14:51 +00:00 WIN-3FL-SW1_1_RP_0_trace_archive_0-20191106-231448.tar.gz
32 -rw- 385508 Nov 14 2019 01:32:49 +00:00 WIN-3FL-SW1_1_RP_0_trace_archive_1-20191114-013246.tar.gz
33 -rw- 386882 Nov 14 2019 01:32:49 +00:00 WIN-3FL-SW1_1_RP_0_trace_archive_3-20191114-013246.tar.gz
34 -rw- 594134 Nov 14 2019 10:49:23 +00:00 WIN-3FL-SW1_1_RP_0_trace_archive_6-20191114-104919.tar.gz
35 -rw- 1588260 Nov 14 2019 22:27:31 +00:00 WIN-3FL-SW1_1_RP_0_trace_archive_0-20191114-222726.tar.gz
36 -rw- 391763 Nov 28 2019 08:19:50 +00:00 WIN-3FL-SW1_1_RP_0_trace_archive_0-20191128-081947.tar.gz
37 -rw- 346899 Dec 9 2019 09:49:49 +00:00 WIN-3FL-SW1_1_RP_0_trace_archive_0-20191209-094947.tar.gz
38 -rw- 330034 Dec 28 2019 23:39:32 +00:00 WIN-3FL-SW1_1_RP_0_trace_archive_1-20191228-233931.tar.gz
825638912 bytes total (738447360 bytes free)
Whao. That is a A LOT OF files!
Are you sure you still want to use 16.11.0?
ok, will upgrade soon and monitor before i share my results, many thanks!!
CSCvq56135
