Catalyst 9300 Stack power wit 8 switches
dm2020
Hi All,
I need to setup an 8-member Catalyst 9300 switch stack that will use Stackpower. I'm aware that a Stackpower ring is limited to 4-member switches, so in my scenario I need to configure two Stackpower rings, however, I cant find any clear cabling guides to achieve this. Does anyone have an example cabling diagram for this please?
2 Accepted Solutions
I agree with Mark. There should be 2 sets of 4.
Also, please remember that power stacking is not a UPS solution and does not protect you against power failure to the whole stack. It only protects you if someone accidentally unplugs one or 2 of the switches from the wall outlet or PDU.
7 Replies 7
Mark Malone
Just an option , instead of trying an unsupported design why not stack power in star topology then you can have all 8
A switch power stack can include a maximum of four switches in a ring topology and eight switches in
a star topology.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/hardware/install/b_c9300_hig/b_c9300_hig_chapter_010.pdf
Hi Mark,
Thanks for the response, however, doesn't a star topology require an RPS? If so, I dont have one of these available so I'm limited to forming stack power rings.
That is correct. If you had an RPS, you could connect up to  9 switches to it, but since you don't have one you are limited to a ring topology using power staking cables.
Yes Reza got back before me :) it does as he and you stated require RPS and i dont want to advise on a power setup i haven't put in place so maybe someone else can shine a light if its possible to do 8 switches somehow even unsupported but personally i would have split the stack into 2 blocks of 4 and dual linked everything back to each of them or gone with a star , one thing about having an unsupported design if you ever have an issue Cisco they will unlikely support it through TAC
Hi Reza,
Do you mean that in the absence of an XPS, 2 powerstacks of 4x 9300s within a datastack of 8x 9300s is a valid configuration? I believe this is the case, but I couldn't find much documentation around it or any user feedback. I really would like to exceed 4 stack members, but the XPS doesn't appeal much.
James.
