Catalyst 9300 Wireless Controller install
John King
Visitor
Hi All,
I am going to be installing a few 9300 switches at my location and I am looking for a guide or information about activating the inbuilt WLC on this platform.
Does anyone have any guides or information on how to activate this feature set? I have come up empty on my searches. I am thinking it has something to do with the install command but I cannot find the right combo to get it working.
8 Replies 8
Leo Laohoo
As of IOS-XE versoin 16.9.1, Converged Access is NOT YET supported/enabled.
Rolino
Community Member
If you could find the solution please share us your solution. Thank you
ccie4549
Frequent Visitor
Frequent Visitor
Hi John,
according to this document https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/config-guide/b_wl_16_10_cg/wireless-sub-package.html you can install the Wireless subpackage but need a DNA Center for provisioning and deployment. I hope this will change so we can use it as a standalone controller.
"Note: Cisco Catalyst 9800 Wireless Controller software on the Cisco Catalyst 9300 switches must be provisioned and deployed on the switch using Cisco DNA Center, and it cannot be configured as a standalone controller."
Jens
Hi All,
This has changed and is available in 17.3.1 IOS-XE now to run the WLC as a standalone (NON-SDA) controller
I am re-reading the 9300 Release Notes for 17.3.1 and I don't see this information anywhere.
Is this them "undocumented feature"?
Hi Leo,
Don't get too exited this still does a form of fabric wireless and uses VxLAN but it does not require DNA-C to be deployed and is classed as non-SDA
For reference see -
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-3/config-guide/b_wl_17_3_cg/m_fiab_gui.html
Thanks for the link.
Preston Chilcote
Need to update this old thread since google thinks it's important.  Embedded WLC on 9300 support (non-SDA) ends after 17.3. It is still supported for SDA deployments with Cisco DNA:
https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9800-series-wireless-controllers/guide-c07-744299.html
