Catalyst Microswitch Series
Taiga2022
I'm particularly interested in these micro series, especially in CMICR-4PT.
From what I've read in datasheet, this device can be powered by POE and can provide POE to downlink ports.
I am unsure about whether this is manage or unmanage switch.
Can I configure this like normal cisco switches?
I want to disable POE in some ports.
Also for the power option for this switch, I don't see the POE injector type to order. May I know what injector I can use?
Also, I want to use this switch as a LAN extender for installation over 100meters.
I also want to know whether I can deploy this switch for extending.
Thank you in advance.
5 Replies 5
balaji.bandi
This runs using AC/ DC PSU, Not from PoE, it deliver Poe from the switch,
it is managed Industrial switch new models, i think you can disable PoE.
check datasheet :
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-micro-switches/nb-06-cat-micro-switch-series-ds-cte-en.html
Some FAQ :
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-micro-switches/nb-06-cat-micro-switch-series-faq-cte-en.html
BB
The data sheet says this though?
Model
Access ports and uplinks
PoE, USB-C
Power source
Default software
CMICR-4PS
4x 1G,
2x 1G SFP
4x PoE+
DC
LAN Lite
CMICR-4PC
4 x 1G,
1x 1G copper, 1x 1G SFP
4x PoE+
DC
LAN Lite
CMICR-4PT
4x 1G,
1x 1G copper, 1x combo
4x PoE+,
2x USB-C
DC, 803.2.bt,
Cisco UPOE+®, PoE+
LAN Lite
Sure agreed, so you looking other than DC source - you want to use PoE to bootup the switch, then you need. i have purchanged one few weeks back to test PoE for Cat 9K AP, that supports  (803.2.bt,Cisco UPOE+®, PoE+)
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/power/guide/air_pwrinj6.html
BB
 As per the data sheet this switch is DNAC ready, which means, it have manageabilty through SNMP, SSH and netconf.
About Power injector , if the doc does not mention any spefic model, I understand that they will work with market standard Power injector as there´s no specific integration between both.
"Also, I want to use this switch as a LAN extender for installation over 100meters. "
What you can safely do is run 100 meter cable from the first switch, install this switch in the end,  and connect a device 100 meter far.  The 100 Meter rule is about ethernet technology and not the switch itself.
Leo Laohoo
The Cisco Micro switches were first announced back in 2019.  Of the three models only CMICR-4PT has never been seen (including CCW).  The three switches will run on the same "cut" as the 2960X, Catalyst 1000 and the IE 4000.
I heard conflicting reasons, like "lack of demand", "global chip shortage" and "future development of classic IOS".
