Catalyst Vlan nat trouble
cabrilloji
  I am having trouble implementing a nat on Catalyst 6500: this is my dafault configuration:
interface Vlan1
no ip address
shutdown
interface Vlan48
description 100
bandwidth 10000000
ip address 193.xx.xx.1 255.255.255.0
This is my public network 193.xx.xx.0 255.255.255.0
interface Vlan50
ip address 130.xx.xx.13 255.255.255.252
interface Vlan65
ip address 10.10.0.1 255.255.0.0
ip nat inside
interface Vlan620
ip address 130.xx.xx.34 255.255.255.252
ip classless
ip route 0.0.0.0 0.0.0.0 130.xx.xx.13
no ip http server
I have a prv network 10.10.0.0 255.255.0.0 and I want using Cisco nat to connect this prv net to the WLAN usin only one ip of my public 193.xx.xx.0 255.255.255.0. (193.xx.xx.254 in this case)
I have made next changes:
interface Vlan1
no ip address
shutdown
interface Vlan48
description 100
bandwidth 10000000
ip nat outside
interface Vlan50
ip address 130.xx.xx.14 255.255.255.252
interface Vlan65
ip nat inside
!Define a new valan for my prv net. vlan65
interface Vlan620
no ip nat service skinny tcp port 2000
no ip nat service H225
ip nat pool WLANPOOL 193.xx.xx.254 193.xx.xx.254 netmask 255.255.255.0
ip nat inside source list 10 pool WLANPOOL overload
ip classless
no ip http server
access-list 10 permit 10.10.0.0 0.0.255.255
I have define a port t vlan65 and a wih a machine on prv net with 10.10.0.1 as gw i can ping to 10.10.0.1 and 193.xx.xx.1 but nothing more:
Router#show ip nat statistics
Total active translations: 0 (0 static, 0 dynamic; 0 extended)
Outside interfaces:
  Vlan48
Inside interfaces:
  Vlan65
Hits: 39  Misses: 3
Expired translations: 2
Dynamic mappings:
-- Inside Source
[Id: 3] access-list 10 pool WLANOVERLOAD refcount 0
pool WLANOVERLOAD: netmask 255.255.255.0
         start 193.xx.xx.254 end 193.xx.xx.254
        type generic, total addresses 1, allocated 0 (0%), misses 0
d23h: NAT: s=10.10.37.37->193.xx.xx.254, d=193.xx.xx.3 [0]
4d23h: NAT*: ICMP id=31280->0
4d23h: NAT*: s=10.10.37.37->193.xx.xx.254, d=193.xx.xx.3 [0]
Any idea about the error?
Regards.
10 Replies 10
Jon Marshall
Iban
Can you clarify something ?
What are you trying to ping ie. what destination address and what does the routing table show for this destination address ? You have a default-route -
the destination IP you are trying to ping, can you post "sh ip route
Jon
Hi Jon,
In the Catalyst most of the ports belong to vlan48 only one port belongs to vlan65(10.10.0.1) in this port I have connected the  10.10.90.60/255.255.0.0 machine.
Router#show ip route 193.xx.xx.0
Routing entry for 193.xx.xx.0/24
  Known via "connected", distance 0, metric 0 (connected, via interface)
  Routing Descriptor Blocks:
  * directly connected, via Vlan48
      Route metric is 0, traffic share count is 1
Router#
   I am tring to ping to my public network from my prv net:
      From 10.10.90.60/255.255.0.0 to  193.xx.xx.1 OK
      From 10.10.90.60/255.255.0.0 to  193.xx.xx.3 FAIL:
1w0d: NAT: ICMP id=16476->0
1w0d: NAT: s=10.10.90.60->193.xx.xx.254, d=193.xx.xx.3 [0]
1w0d: NAT*: ICMP id=16476->0
1w0d: NAT*: s=10.10.90.60->193.xx.xx.254, d=193.xx.xx.3 [0]
Of course no ping to other public/wlan direction ;(
I no have control about  ip route 0.0.0.0 0.0.0.0 130.xx.xx.13 this is the academic network, i only get out with my prv net (10.10.0.0/255) using the one pool 193.xx.xx.254 direction.
If you need more info please let me know.
Iban
Can you try a few things for me -
1) do a ping as is and run "sh ip nat translations"
if you cannot see a NAT translation for your host then
2) change the nat to be -
ip nat inside source list 10 interface vlan 48 overload
ping and run  "sh ip nat translations"
if you still cannot see a NAT translation then -
3) change acl 10 to
access-list 101 permit ip host 10.10.0.0 0.0.255.255. any
ip nat inside source list 101 interface vlan 48 overload
and again ping and look at "sh ip nat translations"
Jon
Hi jon,
I just make an ip nat inside source list 10 interface vlan 48 overload
1w0d: NAT: s=10.10.90.60->193.xx.xx.1, d=193.xx.xx.3 [0]
1w0d: NAT*: ICMP id=0->20573
1w0d: NAT*: s=193.xx.xx.3, d=193.xx.xx.1->10.10.90.60 [48566]
1w0d: NAT*: ICMP id=20573->0
1w0d: NAT*: s=10.10.90.60->193.xx.xx.1, d=193.xx.xx.3 [0]
1w0d: NAT*: s=193.xx.xx.3, d=xx.xx.75.1->10.10.90.60 [48567]
1w0d: NAT*: s=193.xx.xx.3, d=193.xx.xx.1->10.10.90.60 [48568]
1w0d: NAT*: s=193.xx.xx.3, d=193.xx.xx.1->10.10.90.60 [48569]
1w0d: NAT: ICMP id=20829->1
1w0d: NAT: s=10.10.90.60->193.xx.xx.1, d=193.xx.xx.67 [0]
1w0d: NAT*: ICMP id=3->21597
1w0d: NAT*: s=193.xx.xx.67, d=193.xx.xx.1->10.10.90.60 [51826]
Then I can ping to my public network 193.xx.xx.3, 193.xx.xx.36, 193.xx.xx.44 etc
But I cannot ping to my own prv net (10.10.0.2 for example)  and the rest of WLAN (google.com for example), I can resolve the name because 193.xx.xx.3 is my DNS server.
Should I run :
Iban
Should I run :
This is getting confusing. What is 10.10.0.2 ? - you said there was nothing else on this vlan ? The NAT will have no effect if you are pinging within yout own vlan ie. from 10.10.x.x to 10.10.x.x. Check for firewalls on the devices if ping isn't working.
As for internet ie. google.com then again i don't think the NAT is the issue. Is the route to the internet via the 193.x.x.x network ? Please clarify with a diagram or more detailed explanation.
And when you do the ping please post "sh ip nat translations" rather than the debug.
Jon
Hi Jon,
   There is only one port at switch configure to Vlan65 (machine 10.10.90.60 connected) most part of the rest ports belongs to vlan 48:
sh valn
VLAN Name                             Status    Ports
1    default                          active    Gi3/10
48   local                             active    Te1/1, Te1/2, Te1/3, Te1/4
                                                Te2/1, Te2/2, Te2/3, Te2/4
                                                Gi3/3, Gi3/5, Gi3/7, Gi3/11
                                                Gi3/12, Gi3/14, Gi3/15, Gi3/16
                                                Gi3/17, Gi3/18, Gi3/19, Gi3/20
                                                Gi3/21, Gi3/22, Gi3/24
50   Red                          active
55   private                          active
56   Red_10G                      active
65   VLAN0065                         active    Gi3/13
620  RAES                              active
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
at the ports that belongs to vlan 48 are connected machines that belong to prv (10.10.x.x) and public (193.xx.xx.0) (this is not my own configuration, it have been working long time ago)
pinging from 10.10.90.60 to 193.xx.xx.3:
Router#sh ip nat translations
Pro Inside global      Inside local       Outside local      Outside global
udp 193.xx.x.1:4501  10.10.90.60:45935  193.xx.xx.3:53    193.xx.xx.3:53
udp 193.xx.xx.1:4502  10.10.90.60:39918  193.xx.xx.3:53    193.xx.xx.3:53
icmp 193.xx.xx.1:0    10.10.90.60:59247  193.xx.xx.36:59247 193.xx.xx.36:0
udp 193.xx.xx.1:4501  10.10.90.60:45935  193.xx.xx.3:53    193.xx.xx.3:53
So seems the the nat is working
there is no firewall on prv lan:
Is the route to the internet via the 193.x.x.x network ? Really I do not know but seems at router config, seems that the route:
show ip route static
S*   0.0.0.0/0 [1/0] via 130.yy.yy.13
  I have no any control on this network
Iban
interface Vlan48
description 100
bandwidth 10000000
ip nat outside
interface Vlan65
ip nat inside
the above is from your 6500 switch. Then in this post you say -
but this doesn't make any sense because 10.10.x.x is your vlan 65 and if 10.10.x.x ports were configured into vlan 48 you wouldn't be able to get to them because the L3 vlan 48 interface from above doesn't have an IP address for 10.10.x.x.  So if 10.10.0.2 is assigned to vlan 48 then when you try to ping it from 10.10.90.60 it will think it is in the same vlan. So that will never work.
As for the internet it looks to me like it is reachable via the 130.yy.yy.13 route so i'm not sure how you think you can access the internet via your 193.x.x.x network. I thought that you had internet connectivity via the 193.x.x.x but it seems like that is not the case.
Your NAT is working fine. However much of what you have said ie. about the 10.10.x.x network and the internet doesn't make a lot of sense so you need to understand exactly how the 6500 is setup before doing anything else otherwise you could affect the other users.
Jon
Hi Jon,
  Reading a little more about th switches L3 (in my case 6500), i think th i know which is the problem reading ths document :
  http://www.dslreports.com/faq/13563
In my case the nat is workin fine but the packets of my internal network are not routing to  default gw "ip route 0.0.0.0 0.0.0.0 130.206.199.13"
In my case the ports that routes the trafic to out are a trunk of two gigabit 3/1 & 3/2, port-channel1:
interface Port-channel1
switchport
switchport trunk allowed vlan 50,620
switchport mode trunk
no ip address
interface GigabitEthernet3/1
switchport
no ip address
channel-group 1 mode active
interface GigabitEthernet3/2
switchport
no ip address
I think, I should do a "no switchport" on the interface, and the set an "ip" in the same network that the gateway
ip address 130.206.199.14 255.255.255.252 (which is now asigned to vlan50)
I only have a doubt this changes shoud by applied on the physical interface (g 3/1 , g 3/2) or in the
port-channel1 interface
Regards, Iban
Hi Iban,
IP address needs to be configured under the port channel interface. Please visit the following link for details:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.1E/native/configuration/guide/channel.html#wp1020478
Router# configure terminal
Router(config)# interface port-channel 1
Router(config-if)# ip address x.x.x.x 255.255.255.0 (for /24 mask)
Router(config-if)# end
Hope this helps,
Shashank
Please rate if this answered your question
Solved adding :
ip nat outside too to vlan50 (ip nat outside on vlan48 and on vlan 50)
