VLAN interface won't come up
benlemasurier
Level 2
Level 2
I have a few 2921 routers, they all have almost the same configuration (different subnets), on one of them I can't get the vlan interface (Vlan10) to come up, any thoughts??
version 15.1
service password-encryption
hostname a-gw
boot-start-marker
boot system flash c1900-universalk9-mz.SPA.151-4.M.bin
boot-end-marker
aaa new-model
aaa session-id common
clock timezone GMT -7 0
no ipv6 cef
ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.20.1 192.168.20.20
ip dhcp pool PRIMARY
network 192.168.20.0 255.255.255.0
dns-server 192.168.0.77
default-router 192.168.20.1
ip dhcp pool WIRELESS
network 192.168.21.0 255.255.255.0
dns-server 8.8.8.8
default-router 192.168.21.1
ip name-server 192.168.0.77
password encryption aes
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 192.168.0.20 255.255.252.0
ip flow ingress
ip flow egress
ip virtual-reassembly in
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
ip address 192.168.20.1 255.255.255.0
ip flow ingress
ip flow egress
duplex auto
speed auto
interface GigabitEthernet0/0/0
switchport access vlan 10
no ip address
interface GigabitEthernet0/0/1
no ip address
interface GigabitEthernet0/0/2
no ip address
interface GigabitEthernet0/0/3
no ip address
interface Vlan1
no ip address
interface Vlan10
ip address 192.168.21.1 255.255.255.0
ip access-group WIRELESS in
ip access-group WIRELESS out
router eigrp 10
network 192.168.0.0 0.0.3.255
ip default-gateway 192.168.0.1
ip forward-protocol nd
ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.0.1
ip access-list extended WIRELESS
permit ip host 192.168.21.2 any
deny   ip any 192.168.0.0 0.0.3.255
permit ip any any
access-list 23 permit 10.10.10.0 0.0.0.63
access-list 23 permit 192.168.0.0 0.0.255.255
snmp-server community public RO
control-plane
banner login
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
transport input ssh
line vty 5 15
access-class 23 in
transport input ssh
scheduler allocate 20000 1000
ntp update-calendar
ntp peer 91.189.94.4
end
# sh ip int bri
GigabitEthernet0/0         192.168.0.20    YES NVRAM  up                    up
GigabitEthernet0/1         192.168.20.1    YES NVRAM  up                    up
GigabitEthernet0/0/0       unassigned      YES unset  up                    up
GigabitEthernet0/0/1       unassigned      YES unset  down                  down
GigabitEthernet0/0/2       unassigned      YES unset  down                  down
GigabitEthernet0/0/3       unassigned      YES unset  down                  down
Vlan1                      unassigned      YES unset  down                  down
Vlan10                     192.168.21.1    YES NVRAM  down                  down
benlemasurier
Level 2
Level 2
well, I'm not sure why, but I did the following:
a-gw#config t
Enter configuration commands, one per line.  End with CNTL/Z.
a-gw(config)#interface gigabitEthernet 0/0/0
a-gw(config-if)#no switchport access vlan 10
a-gw(config-if)#switchport access vlan 10
% Access VLAN does not exist. Creating vlan 10
This fixed the issue!
t_mcwilliams
Frequent Visitor
Frequent Visitor
Is vlan10 showing in the vlan database?
