Monitor session destination port traffic load problem.
gsancassano
I'm running into a problem with monitor session.
I have configured 2 monitor session and monitor session 2 have only one source port and one destination port.
The problem is that the source port has little traffic but in the destination port I see more traffic (more than the sum of rx and tx). In the source interface I have only 254 packets/second (both rx and tx) and 941000bps. In the destination port I see 1016 packets/second and 9Mbps.
How can be this?
I have made some test, changing the source and destination ports, but the problem persists. Also I delete all de monitor session 2 and start the configuration again, but also continue the problem.
What you suggest me to do or test so I can solve de problem?
monitor session 2 source interface Gi2/26
monitor session 2 destination interface Gi1/47
6509#sh int  Gi2/26
GigabitEthernet2/26 is up, line protocol is up (connected)
  Hardware is C6k 1000Mb 802.3, address is 001f.9f3e.5019 (bia 001f.9e3e.0519)
  Description: WEBSERVICE
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseT
  input flow-control is off, output flow-control is on
  Clock mode is auto
  Last input never, output never, output hang never
  Last clearing of "show interface" counters 00:05:01
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  30 second input rate 424000 bits/sec, 109 packets/sec
  30 second output rate 517000 bits/sec, 145 packets/sec
     35084 packets input, 17292139 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     48616 packets output, 21320737 bytes, 0 underruns
6509#sh int  Gi1/47
GigabitEthernet1/47 is up, line protocol is down (monitoring)
  Hardware is C6k 1000Mb 802.3, address is 001f.9e3f.505e (bia 001f.9e3e.055e)
  Description: SPAN
     reliability 255/255, txload 2/255, rxload 1/255
  input flow-control is off, output flow-control is off
  Clock mode is auto
  Last input never, output 00:06:37, output hang never
  Last clearing of "show interface" counters 00:05:30
  30 second input rate 0 bits/sec, 0 packets/sec
  30 second output rate 9093000 bits/sec, 1016 packets/sec
     8 packets input, 576 bytes, 0 no buffer
     364895 packets output, 414782539 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
6509#
6509#sho monitor session 2
Session 2
Type                   : Local Session
Source Ports           :
    Both               : Gi2/26
Destination Ports      : Gi1/47
Egress SPAN  Replication State:
Operational mode       : Centralized
Configured mode        : Centralized (default)
6509#
Thanks in advance.
Eugene Lau
G'day!
The first thing I'd check -  verify what is the extra traffic?
1. Does the issue happening with just RX or TX? It could simpify the view and traffic
2. What version of IOS and hardware?
#sh ver
#sh mod
3. Is the switch in VSS mode?
4. What is connected to the source port?
If you can review the sniffer trace to see what some of the differences in traffic are, it could lead you to speculate what may be occurring.
Example
- if you see traffic from another port on the LC (Line card) - it could be an issue with IOS programming - incorrectly forwarding traffic from other ports to the SPAN Destination
- some type of duplication etc
Eugene
Eugene, thanks for you replay.
We have solve the problem setting the speed and duplex in de monitor session destination port.
Thanks.
