CDP Not showing Neighbours
daniel.akinin
I am attempting to update our network diagrams and am finding with some sites that the neighbours do not show up.
CDP is enabled on the switch and router from what I can tell.
The router is a 3550 and switch is a 2950, for this particular site the core router will not show any neighbours, although if you connect to a switch it will show the router.
As with some switches will show their neighbours and others will not.
Any pointers in what to check, or even with this occuring is there an easy way to find out neighbours of a device without CDP working.
Dan
10 Replies 10
Hieu Cao
Level 4
Level 4
Dan,
Have you tried comparing the configs between what's working from what's not working? Can you post the config?
hieu
Here is the config of the router..
! Last configuration change at 09:14:41 Eastern Mon Apr 30 2007
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname ---
enable secret xxx
clock timezone Easternstandard 10
clock summer-time Easternsummer recurring last Sun Oct 2:00 last Sun Mar 3:00
ip subnet-zero
ip routing
mls qos
interface Loopback0
description Management_Interface
ip address xxx.xxx.xxx.xxx 255.255.255.255
interface Port-channel1
switchport trunk allowed vlan 10,20,100,300,1002-1005
switchport mode trunk
no ip address
interface GigabitEthernet0/1
description WAN_Interface
no switchport
ip address xxx.xxx.xxx.xxx 255.255.255.252
interface GigabitEthernet0/2
description Spare_trunk_Tie
no ip address
interface GigabitEthernet0/3
no ip address
interface GigabitEthernet0/4
no ip address
interface GigabitEthernet0/5
no ip address
interface GigabitEthernet0/6
no ip address
interface GigabitEthernet0/7
no ip address
interface GigabitEthernet0/8
no ip address
interface GigabitEthernet0/9
no ip address
interface GigabitEthernet0/10
no ip address
interface GigabitEthernet0/11
no ip address
duplex full
speed 1000
channel-group 1 mode on
interface GigabitEthernet0/12
description Server_Switch
no ip address
duplex full
speed 1000
interface Vlan1
description Not in Use
no ip address
shutdown
interface Vlan10
description IT_Faculty
no ip address
ip access-group ITfaculty in
interface Vlan20
description ITFaculty
ip address xxx.xxx.xxx.xxx 255.255.254.0
interface Vlan100
description Data
interface Vlan300
description Voice
ip helper-address xxx.xxx.xxx.xxx
ip classless
ip route 0.0.0.0 0.0.0.0 xxx.xxx.xxx.xxx name LastResort
ip http server
Daniel
I believe that there is a significant clue about what is going on in this statement from your post: "The router is a 3550 and switch is a 2950, for this particular site the core router will not show any neighbours, although if you connect to a switch it will show the router." I believe that it confirms what the config shows which is that CDP is running on the router.
My guess is that CDP is not running on the switch interfaces. It would be helpful if you would post the output of show cdp interface from both the router and the switch.
Rick
Rick
*** Example From Switch ***
6073--MG12ES001#show cdp
Global CDP information:
Sending CDP packets every 60 seconds
Sending a holdtime value of 180 seconds
Sending CDPv2 advertisements is enabled
6073--MG12ES001#
6073--MG12ES001#show cdp interface
FastEthernet0/1 is up, line protocol is up
Encapsulation ARPA
Holdtime is 180 seconds
FastEthernet0/2 is up, line protocol is up
Encapsulation ARPA
FastEthernet0/3 is up, line protocol is up
Encapsulation ARPA
*** Example from router ***
6073--AG23LR002#show cdp
6073--AG23LR002#show cdp inter
6073--AG23LR002#show cdp interface
GigabitEthernet0/1 is up, line protocol is up
Encapsulation ARPA
GigabitEthernet0/2 is down, line protocol is down
Encapsulation ARPA
GigabitEthernet0/3 is down, line protocol is down
Encapsulation ARPA
Daniel
Thanks for posting the additional information. While it does not give me the answer, perhaps it allows us to get a bit deeper into the issue. It does show that CDP is globally enabled on the router and on the switch.
I note that the output indicates that the router gig0/1 is an access port and is up/up but that gig0/2 and gig0/3 are trunk ports and are down/down. Is there some issue with these ports? Perhaps we need some output to be posted to show who sees neighbors on what interfaces.
Rick
Rick
Hi Rick,
From the information I have been able to gather, it appears there are no devices on these ports mentioned above, there are devices connected only to those ports showing as up/up.
Hope I am on the right track here :)
Dan
Dan
If there are no devices connected on these ports it would certainly explain why they are down/down.
Rick
Rick
jeff.teoch
Hi Dan,
I think you should specify which port on the switch and the router were being used to connect to each other in order to avoid the confusion of up/up or down/down.
Jeff
glen.grant
I have seen this at times with cisco and it does behave as you have suggested . A few times I have been able to fix it by doing a "clear interface " on the attaching interfaces and cdp would start showing up again otherwise you may be stuck either living with it or reload the devices to see if that would fix it . Might want to consider upgrading the 3550 it looks like it is still running 12.1 code which is way out of date for the 3550 .
daniel.akinin
Thanks all for you reponses and time, we have updated the names on each switch to bring them into standard and they are now showing up on CDP.
Got love these problems.
Dan
