Chassis S/N
jayeshtjayaraj
Hi ,
How we can check the chassis serial number ( Not Process ID).
My switch is Cisco WS-C6509. Show Inventory and Show Diag is not working in this switch.
Is there any other cmd for getting the chassis S/N.
6 Replies 6
Rolf Fischer
Level 9
Level 9
you could try 'show snmp', normally the first line shows the SN as well.
I wonder why show inventory doesn't work. What IOS version are you running?
Rolf
Sent from Cisco Technical Support Android App
John Blakley
I also wonder why show inventory doesn't work, but if you do a show ver, the Processor board ID is the Chassis serial number...at least it matches mine.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
I confirm this,
Br,
Jean-Yves
Leo Laohoo
That's wierd.  I always use "sh inventory raw" and the first line is the chassis' serial number.  If not, then if you haven SNMP enabled, use the command "sh snmp" and it'll come up as well.
glen.grant
Show idprom chassis or show idprom backplane .  If it's really old and its a hybrid box seems like it was show system or something like that on catos.
glen.grant
  Try   show version ...
