cisco 2621xm Bootstrap Upgrade
warquezho0612
How to I upgrade the bootstrap of my 2621xm so that I can upgrade it to latest IOS and for the 256mb ram to be used instead of 128mb?
Router#show version
IOS (tm) C2600 Software (C2600-JS-M), Version 12.2(16), RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Fri 07-Mar-03 01:45 by pwade
Image text-base: 0x8000808C, data-base: 0x8145B328
ROM: System Bootstrap, Version 12.2(7r) [cmong 7r], RELEASE SOFTWARE (fc1)
Router uptime is 1 minute
System image file is "flash:c2600-js-mz.122-16.bin"
cisco 2621XM (MPC860P) processor (revision 0x100) with 125952K/5120K bytes of memory.
Processor board ID JAD07100G3T (728141824)
M860 processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
2 FastEthernet/IEEE 802.3 interface(s)
2 Serial(sync/async) network interface(s)
32K bytes of non-volatile configuration memory.
49152K bytes of processor board System flash (Read/Write)
I look at the cisco site for 2621xm bootstrap and found none.. Where can I download the latest boostrap?
amikat
It has been quite some time ago since I worked with these devices. If I remember correctly the system bootstrap (rommon) resides in boot ROM, ie. it cannot be erased or re-programmed but it should be replaced instead (it is socketed). For the 256MB RAM you need 12.2(8r) version (you currently have 12.2(7r) version). In old days the rommon could be ordered from Cisco (either separately or with the RAM upgrade). But as these devices reached EOL & EOS stage, I really doubt this would be an option now.
I am sorry I cannot be more helpful.
Best regards,
Antonin
Found the solution, need to replace the old bootrom with a newer one that is 12.2(8r) version!
