01-11-2011 10:01 AM - edited 03-06-2019 02:55 PM
I purchased 2 Cisco2650 (non MX version) from Ebay and to my surprise has IOS 12.4 (12) installed on both. I thought only the XM versions of 2600 series could support 12.4 and non-MX 12.3.
Is the Cisco2650 actually 2650MX (It does not show/say MX anywhere on the device, just Cisco2650).
01-11-2011 12:17 PM
For a true 2650 router 12.3.26 was the last version that was released . A show version will tell you if its a XM or not otherwise they have the wrong IOS on it .
01-11-2011 12:26 PM
Thats interesting, When I get home I will run and see. Thank you.
I didn't even know it would allow you to put 12.4 on a device that maxes out at 12.3. Do your forsee any issues of keeping it this way?
01-11-2011 09:31 PM
Cisco2650-1>sh ver
Cisco IOS Software, C2600 Software (C2600-IPBASEK9-M), Version 12.4(12), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Fri 17-Nov-06 11:18 by prod_rel_team
ROM: System Bootstrap, Version 12.1(3r)T2, RELEASE SOFTWARE (fc1)
Cisco2650-1 uptime is 1 minute
System image file is "flash:c2600-ipbasek9-mz.124-12.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco 2650 (MPC860P) processor (revision 2.0) with 127627K/3445K bytes of memory.
Processor board ID JAB05310D2F
M860 processor: part number 5, mask 2
1 FastEthernet interface
2 Low-speed serial(sync/async) interfaces
32K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
