Cisco 2960X Question
scooter817
Level 2
Level 2
Hi Everyone
I wanted to know is there a chart someone on Cisco that I can look at to tell me what is the difference between these 2 switches that I have. They both are 2960X series, they both are 48 ports but they have different numbers. One is a LPD-L and the other is a FPS-L, I want to know what these letters mean because I would like to standardize what we have so the next time I order one I tell the vendor the exact model number.
Eric
2 Accepted Solutions
michael.burke
Leo Laohoo
LPD can be broken down as:
P stands for PoE with 370w PoE allowance
D stands for SFP/SFP+ support
FPS can be broken down as
FP means Full PoE power.  This can only be found in 48-port switches.  This means there is a power supply which supply 750w PoE.
S means SFP only support
5 Replies 5
michael.burke
It has to do with POE.  One is Low Power 370w the Other is Full Power 740w.
https://www.cisco.com/c/en/us/products/switches/catalyst-2960-x-series-switches/models-comparison.html
Leo Laohoo
What you just explained is what I want to know, is there a chart that will show you what these letters mean.
Like how I broke the letters down? No.
If you need them, TAC should be able to provide them.
Yes
I like how you explained what each letter stands for and thanks alot
