Cisco ASA routing guest VLAN
jkay18041
Level 3
Level 3
I am having some issues getting my guest VLAN to route through my Cisco ASA.
I've got port 4 setup with the IP of 192.168.100.1 and I want to use an IP in our public IP subnet of (example) 5.4.3.2/26
I've got my switch setup to handle DHCP for the Guest VLAN and I'm using a ruckus controller.
So port 4 on the ASA is the only used for Guest VLAN 5. I can ping from a device connected on the wireless network 192.168.100.1 so I know traffic is getting to the ASA I'm assuming my NAT is setup wrong.
Any advice on how to get this working correctly?
Thank you
post the full configuration of your ASA...
I don't see the attachment ?
