Cisco 3560 reset to factory default
Soren09
hi, can any one help with this issue? could not connect to cisco 3560 , may be wrong start-up config/deleted. i want to reset it to factory setting so that i can restart to express set up: when trying with button mode, the LED's BLink but switch won't restart.
thanks
2 Accepted Solutions
Seb Rupik
Hi there,
You need to power down the switch, power it back on with the mode button pressed. You will eventually arrive at the switch: prompt. From there you can either delete or rename the existing config:
flash_init
rename flash:config.text flash:config.old
Then issue the boot command.
cheers,
Seb.
10 Replies 10
Seb Rupik
Hi there,
flash_init
cheers,
Seb.
thanks Seb, so when rebooting , how to acces the switch prompt? using the console,usb or RJ45 cable?
you dont need to power it down, if its powered up just press the mode button for 30 seconds then release
Hi, I tried biut it didn't work at the boot commande, saying "Error loading " "
You have to initialize the flash after deleting the config file.
Soren09
thanks Guys, helped!
charlesfreukes
Flash_init will do it but if your disposing of the switch you should delete the config and vlan data
Instead of renaming the config delete it
flash_init
delete flash:config.text
delete flash:vlan.dat
boot
Thank you. Worked great.
Hello, I tried your method but itt says " Error loading "" ", could you help please ?
