Cisco 3750. IP Routing Command not exisitant!!
Colourful
I have just bought two Cisco 3750 and stacked them. When in global config mode, The IP Routing Command does not exisit. Help appreciated ASAP.
See Version below
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 12.2(55)SE3, RELEASE SOFTWARE (fc1)
Technical Support:
http://www.cisco.com/techsupport
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 05-May-11 15:40 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x02800000
5 Replies 5
Reza Sharifi
What is your license level?
sh license
also
sh ver
My current license level is LAN Base. Is this the issue? If so how do I gain the correct license?
That is really weird the 3750E is not even suposed to support LAN Base. That said this would be your problem LAN base only supports layer 2 fuctions.
Are these 3750Es or 3750Xs with the E image running on them? If so you would need to buy a licence upgrade for these devices such as "L-C3750X-48-L-S" licence to upgrade from LAN Base to IP Base if the switch is 48 port. The datasheet has more info under the "Product Activation Process" section.
These are the 3750Xs with the 12.2 55 Image
Contact your cisco reseller, and buy the upgraded license.
