Cisco 3750 Switch does not allow ICMP traffic
Edward M.
Dear All,
I am junior network administrator and pretty new in cisco networking world.
I'm not quite sure why my Cisco 3750 switch do not pass the ICMP/traceroute traffic.
I have ASA Firewall A which is connected to ASA Firewall B through a Cisco Switch between which does routing for LANs behind the firewalls. The routing and required ACLs are configured on both firewalls, and there is no ACL configured on the switch.
I have one Windows VM running behind Firewall B and I can access the LAN and ping nodes behind firewall A from the VM,
but when I trace route the same nodes, it stocks on Cisco switch and it does not pass it to firewall A as next hop.
Appreciate your advise and help.
Ed
5 Replies 5
If you see the IP of the 3750, that means it responded. By default, ASA firewalls do not respond/participate to traceroute requests. You would also need to make sure that the lower security interface of the ASA permits ICMP unreachable for traceroute to work correctly through it.
Dear Elliot, Thanks for your reply.
I do see the 3750 IP in trace route output,  and I assume that it has passed the firewall B already even though I don't see the FW B interface IP.
I have also ACLs on both interface of FW A allowing ICMP traffic for both ping and traceroute, but still no joy.
It isn't traceroute that you need to allow, it is time-exceeded. I mispoke in the first post. The response in trace route is a time-exceeded ICMP packet which must be explicitly permitted in the ACL of the lower security interface.
Thanks Ellliot,
I added the  icmp/time-exceeded to the ACL on all interfaces of FW A.
So I have icmp, icmp/time-exceeded, icmp/traceroute, icmp/unreachable but still no joy.
In the asa's, do "debug icmp trace" and see what output you get. Have a CLI session open to both ASA's that are part of the path. That should give you an idea what is happening.
