Maximum SPAN sessions on different switches
ivanchello
For my task, I need to buy a switch that supports at least two SPAN sessions. I'm looking at SF350/SF352 or catalyst 2960cpd-8tt-l. However, the datasheets of these models do not contain information about the maximum number of sessions. Before I buy something, I need to be sure about it. Help me please.
And if these models support only one session, please tell me a switch with a small number of ports that allows you to configure at least 2 SPAN sessions.
balaji.bandi
Most the information related to SPAN will be in the configuration guide and any Limitration depends on IOS code running you can look configuration guide example for 2960 : (Traffic monitoring in a SPAN session has these restrictions:)
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/software/release/12-2_55_se/configuration/guide/scg_2960/swspan.html
SMB switches example :
https://www.cisco.com/c/en/us/td/docs/switches/lan/csbms/CBS_250_350/CLI/cbs-250-cli/span-and-rspan-commands.html
BB
Thank you very much for the articles, I have already read them.
Now I have another question. The number of sessions within the same series may differ? Does an 8 port 2960 series switch have exactly the same number of sessions as SPAN on a 24 port 2960 series?
In the second article, you gave examples where the CBS250 / 350 is configured, but I need to configure the SF350. Or will they have the same setup?
Thank you!
