Cisco 3750G switch issue
kevintang
Level 4
Level 4
HI,
I have two cisco 3750G switch. one of them is working fine (good performance) with the old 10MB/half interface device. But another 3750G switch has bad performance with the same old 10MB/half interface device. Both switch are running same latest IOS and same configuration on the interface. Any idea?
5 Replies 5
royalblues
Level 11
Level 11
Since the device is running at half duplex it may be receiving lot of collisions affecting the performance.
Do you see any difference in the interface statistics when connected to the good and bad 3750 switch.
Try Hardcoding the interface on the 3750 to 10 half which can eliminate negotiation problems.
Narayan
Yes, we can see the difference. we have tried all possiable configuration the interface. but just one of them is better than another one.
===good one:====
Transmit GigabitEthernet1/0/17 Receive
576135912 Bytes 906812993 Bytes
110164320 Unicast frames 658437 Unicast frames
3448619 Multicast frames 3 Multicast frames
5880870 Broadcast frames 5080 Broadcast frames
0 Too old frames 905976508 Unicast bytes
294668 Deferred frames 192 Multicast bytes
0 MTU exceeded frames 828430 Broadcast bytes
218 1 collision frames 0 Alignment errors
186 2 collision frames 0 FCS errors
145 3 collision frames 0 Oversize frames
31 4 collision frames 0 Undersize frames
14 5 collision frames 1964 Collision fragments
10 6 collision frames
20 7 collision frames 29364 Minimum size frames
5 8 collision frames 24337 65 to 127 byte frames
12 9 collision frames 16837 128 to 255 byte frames
32 10 collision frames 1439 256 to 511 byte frames
12 11 collision frames 54 512 to 1023 byte frames
1 12 collision frames 591489 1024 to 1518 byte frames
0 13 collision frames 0 Overrun frames
0 14 collision frames 0 Pause frames
0 15 collision frames
0 Excessive collisions 0 Symbol error frames
0 Late collisions 0 Invalid frames, too large
0 VLAN discard frames 0 Valid frames, too large
0 Excess defer frames 1964 Invalid frames, too small
32300661 64 byte frames 0 Valid frames, too small
86450813 127 byte frames
241328 255 byte frames 0 Too old frames
122318 511 byte frames 0 Valid oversize frames
7459 1023 byte frames 0 System FCS error frames
371230 1518 byte frames 0 RxPortFifoFull drop frame
0 Too large frames
218 Good (1 coll) frames
468 Good (>1 coll) frames
========bad one======================
Transmit GigabitEthernet2/0/17 Receive
1433768758 Bytes 2839558401 Bytes
216481351 Unicast frames 162234648 Unicast frames
17884645 Multicast frames 0 Multicast frames
7697564 Broadcast frames 41 Broadcast frames
0 Too old frames 2836524031 Unicast bytes
95797 Deferred frames 0 Multicast bytes
0 MTU exceeded frames 2624 Broadcast bytes
535176 1 collision frames 0 Alignment errors
82952 2 collision frames 0 FCS errors
14709 3 collision frames 3 Oversize frames
1362 4 collision frames 1 Undersize frames
40 5 collision frames 750853 Collision fragments
0 7 collision frames 96320 Minimum size frames
0 8 collision frames 162132464 65 to 127 byte frames
0 9 collision frames 3216 128 to 255 byte frames
0 10 collision frames 2689 256 to 511 byte frames
0 11 collision frames 0 512 to 1023 byte frames
0 12 collision frames 0 1024 to 1518 byte frames
1 Late collisions 3 Invalid frames, too large
0 VLAN discard frames 7 Valid frames, too large
0 Excess defer frames 750853 Invalid frames, too small
88729000 64 byte frames 1 Valid frames, too small
93194636 127 byte frames
1976739 255 byte frames 0 Too old frames
1503897 511 byte frames 7 Valid oversize frames
1369413 1023 byte frames 0 System FCS error frames
55289876 1518 byte frames 0 RxPortFifoFull drop frame
0 Too large frames
535176 Good (1 coll) frames
99063 Good (>1 coll) frames
can u hardset speed/duplex to 10/half on the swicth which is not giving good performance.
after that clear counters and see if things have changed for you or if it is still working the way it is working before.
glen.grant
You need to take a look at the device and see how the nic card is set if its auto/auto or hardcoded and then you have to match whatever the nic is set at . Is this a real old device , very few devices have to run at 10/half I would check to see if it will runn auto or can hardcode to 100/full .
