Cisco 3850 with Denali 16.3.6 + RADIUS
Jay_Work
Have an odd thing going on with our L3 routing switch when it comes to setting radius authentication up on it. On the other switches that are not L3 with Denali 16.3.6 authentication and logging into the switches via RADIUS works fine. However, this particular switch is for some reason not connecting back to the RADIUS server.
From the Switch I can:
Ping the RADIUS server - can ping the switch from the RADIUS (NPS) server
run a terminal monitor and debug radius
open another session and log in with my AD credentials. This is where it fails. The debug shows it attempting to go out to the radius server IP but then receives 3x request timed out messages.
Its not a routing issue as i'm able to ping from the switch and from the server.
Is there something I'm missing with this version of Denali? there is no difference with my configuration here to the other switches.
Hi, managed to sort it now. I discovered the IP address of where the packets were coming from, from using the debug command and added this IP address into my NPS radius client and connection policy. It work immediately. Thankyou for your help.
6 Replies 6
balaji.bandi
we have several 3850 in the network using ACS 5.8 (in the background with AD Credential)
did not see any issue
here my show version
Switch Ports Model SW Version SW Image Mode
* 1 56 WS-C3850-48P 16.3.6 CAT3K_CAA-UNIVERSALK9 INSTALL
show us your configuration and see what ACS logs says ?
BB
Not much to show from the debug logs other than its timing out. I just thought I would ask to see if others had an issue after upgrading to denali 16.3.6
We use radius on Denali too no issues 16.3.7
did you diff the config after the upgrade make sure something wasnt removed
Suggest to post config from switch side, i am sure there may be some logs on ACS why it failing.
BB
Glad to hear all working, if resolved mark as resolved so other community members can have the solution.
BB
