Cisco 6500 - system log
CSCO11177789
Hi;
When i wrote on the system console "sh logging system" , i take
1: 10/19/10 12:55:20    5/-1: MAJ, GOLD, diag_get_fabric_status[2]: diag_hit_sys_limit: Test skipped!
  2: 10/19/10 12:55:20    5/-1: MAJ, GOLD, diag_get_fabric_status[1]: diag_hit_sys_limit: Test skipped!
  3: 10/19/10 12:55:20    5/-1: MAJ, GOLD, diag_get_fabric_status[9]: diag_hit_sys_limit: Test skipped!
this output many times. What does it mean ?
7 Replies 7
Yogesh Ramdoss
This message is reported by GOLD - General OnLine Diagnostic feature.
GOLD perodically gets fabric status of all fabric-enabled modules. When the CPU has something (important/higher priority) to do, it skips the test.
- Yogesh
Hello;
First of all, thank you for your great support. I attached the "sh proc cpu" output. Is ıt normal usage ? In detail information i couldnt see anything.
Thanks.
sh processes cpu | exclude 0.00%  0.00%  0.00%
CPU utilization for five seconds: 39%/29% <<==
Total CPU usage is 39% - 10% due to processes and 29% due to interrupts.
I guess, some traffic may be getting software-cef switched.
Please review following documents and see if it helps.
Troubleshooting High CPU in Cisco Routers:
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a00800a70f2.shtml
Troubleshooting High CPU due to interrupts:
http://www.cisco.com/en/US/products/hw/routers/ps359/products_tech_note09186a00801c2af0.shtml
- Yogesh
Hi again;
As you say , i think i've problem about ip cef. On console i wrote "sh cef not-cef-switched" and took attached display.
What does "unsupported" mean ? Also this column continuously increase.
"sh cef not-cef-switched" has not been very useful. Please do "sh ip cef switching statistics feature" few times, and you should be able to identify the feature that may be sending traffic for software-cef switching.
- Yogesh
Thank you for your support.
I ' ll try.
This is General OnLine Diagnostic alert message for fabric test
