Intervlan routing using One L3 switch
prajithtr_2
Level 4
Level 4
haii everybody,
    Suppose we have two layer2 switches(2960) and one multi layer switch(catalyst3560) .These two layer2 switches carry 3 vlans (vlan20,vlan30,vlan40).and there is no router or other layer 3 device .with these devices is it  possible to set up intervlan routing.if possible could you pls give a sample configuration.
dschoolcraft
Configuration for the 3560
!enable ip routing on the 3560
ip routing
system mtu routing 1500
! Note the IP's Listed here would need to be your Default Gateways on the Hosts
interface vlan 1
interface vlan 10
ip address 192.168.2.1 255.255.255.0
interface vlan 20
ip address 192.168.3.1 255.255.255.0
!Enable a routing protocol for intervlan routing
router eigrp 1
network 192.168.1.0
network 192.168.2.0
network 192.168.3.0
! NOTE IF you have a non Gig switch it would be FastEthernet0/1
interface GigabitEthernet0/1
description link to 2960 1
switchport trunk encap dot1q
switchport mode trunk
description link to 2960 2
2960 Configuration
description trunk to 3560 port g0/1
2960 2 config
interface GigabitEthernet0/2
description trunk to 3560 port g0/2
Then assign your switchports on the 2960's as needed
Interface GigabitEthernet0/Some number
switchport access vlan 20
switchport mode access
spanning-tree portfast
Substitute your interface names & IP's as necessary
dschoolcraft
ip routing
interface vlan 1
interface vlan 10
interface vlan 20
router eigrp 1
network 192.168.1.0
network 192.168.2.0
network 192.168.3.0
2960 Configuration
2960 2 config
hai,
   thank you...for  your immediate reply.your answar was defenitely helpfull.
glen.grant
  Yes a 3560 will do your intervlan routing and a lot faster than a normal router also .
Naveen Kumar Rajaharia
Community Member
Perform below configs
L2 Switch
1) Create L2 vlans
2) Configure default gateway as L3 switch
3) Create L2 trunk to the L3 switch
L3 Switch
1) Create Vlan SVI, assign IP address
2) Create L2 trunk connecting to L2 Switch
3) Advertise the network under protocol in L3 switch
