CISCO 6500 VSS - Problem after convertion
Hello everyone!
i need your help, i convert my cisco 6509E to VSS mode and after reboot, the SW2 present this problem
CEN_VSS#show mod sw 2
Switch Number: 2 Role: Virtual Switch Standby
Mod Ports Card Type Model Serial No.
1 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL1440V9W8
2 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL1440VLL9
3 24 CEF720 24 port 1000mb SFP WS-X6724-SFP SAL1440VELK
4 6 Firewall Module WS-SVC-FWM-1 SAL1439UWS2
5 5 Supervisor Engine 720 10GE (Hot) VS-S720-10G SAL1440VME5
Mod MAC addresses Hw Fw Sw Status
1 1cdf.0f90.3038 to 1cdf.0f90.3067 3.4 Unknown Unknown Other
2 c84c.757c.f57c to c84c.757c.f5ab 3.4 Unknown Unknown PwrDown
3 1cdf.0f7b.bd88 to 1cdf.0f7b.bd9f 5.0 Unknown Unknown PwrDown
4 f866.f29a.2230 to f866.f29a.2237 4.5 Unknown Unknown PwrDown
5 0024.14e5.5040 to 0024.14e5.5047 3.2 8.5(4) 12.2(33)SXI4 Ok
Mod Sub-Module Model Serial Hw Status
1 Centralized Forwarding Card WS-F6700-CFC SAL1440V9JN 4.1 Other
2 Centralized Forwarding Card WS-F6700-CFC SAL1440V165 4.1 PwrDown
3 Centralized Forwarding Card WS-F6700-CFC SAL1440VJC9 4.1 PwrDown
5 Policy Feature Card 3 VS-F6K-PFC3C SAL1440VF1T 1.1 Ok
5 MSFC3 Daughterboard VS-F6K-MSFC3 SAL1439UQMF 5.1 Ok
Mod Online Diag Status
1 Not Applicable
2 Not Applicable
3 Not Applicable
4 Not Applicable
5 Pass
try to reset single module and i try to removed and inserted module SLOT 1,2,3 but nothing's changed, and i try to reboot the sw2.
this is example to my log:
Sep 10 13:39:06.617: %C6KPWR-SW2_SPSTBY-4-DISABLED: power to module in slot 3 set off (Module Failed SCP dnld)
Sep 10 13:43:28.841: SW1_SP: Switch 2 Physical Slot 3 - Module Type LINE_CARD removed
Sep 10 13:43:28.857: SW1_SP: Switch 2 Physical Slot 3 - Module Type LINE_CARD inserted
balaji.bandi
here is the troubleshoot guide :
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-series-switches/116115-trouble-linecard-00.html
For now looks like Hardware issue, can you post complete Logs of boot
BB
Scott Hodgdon
Cristina,
Before rebooting during the VSS conversion, how long had it been since the chassis was rebooted ?
You may be hitting this: https://www.cisco.com/c/en/us/support/docs/field-notices/637/fn63743.html
Please call TAC and let them investigate.
Cheers,
Scott Hodgdon
Senior Technical Marketing Engineer
Enterprise Networking Group
Leo Laohoo
Based on the serial numbers of the 6748-GE-TX and 6724-SFP, I would say all three were manufactured on the first week of October 2010.
Because of this, I believe the following line cards are affected by the Memory Component Issue (Field Notice: FN - 63743 - Catalyst 6500 - Might Fail to Boot Up After a Software Upgrade or Power Cycle).
