10-30-2022 03:00 PM
Dear Cisco Community Team,
I would like some help and guidance on fixing an issue I have with 2 Cisco 6513 switches.
The 2 Cisco 6513 switches are working as my data center switches connecting most of our systems to it.
The CPU have been spiking multiple times every hour.
Is there a guide that I can follow to narrow down the cause and solve it? any suggestion or recommendation would be highly appreciated.
Note: in the attached files you will find the "show proc cpu history" and " show proc cpu sorted 5min | ex 0.0" please let me know if you want me to provide more info.
cr-6513-sw1#show processes cpu sorted 5min | ex 0.0
CPU utilization for five seconds: 8%/0%; one minute: 39%; five minutes: 39%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
200 33754772 66353407 508 4.63% 4.18% 3.99% 0 slcp process
723 9045584 63423748 142 1.35% 0.79% 0.78% 0 Port manager per
776 6929664 5195816 1333 1.03% 0.73% 0.71% 0 LTL MGR
686 3570828 984029 3628 0.47% 0.38% 0.38% 0 Env Poll
433 4512604 57183817 78 0.15% 0.21% 0.24% 0 IP Input
cr-6513-sw2#show processes cpu sorted 5min | ex 0.0
CPU utilization for five seconds: 9%/0%; one minute: 42%; five minutes: 39%
200 33314004 66643053 499 1.08% 3.82% 3.88% 0 slcp process
399 16601296 2243405 7400 4.18% 2.18% 2.06% 0 Lif stats RP tas
686 3573008 994115 3594 0.41% 0.37% 0.38% 0 Env Poll
10-30-2022 11:45 PM
- FYI : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCur96442
M.
10-31-2022 08:08 AM
Thanks @Mark Elsen that link is very useful.
The only thing is that the switches were working normally until we did a power shutdown to fix the UPS and after we powered them up it was like that, not sure what am I missing and if we can find a work around it?
Also does an IOS upgrade and/Or another reboot will change things?
cr-6513-sw1#sh version
Cisco IOS Software, s2t54 Software (s2t54-IPSERVICESK9-M), Version 15.5(1)SY5, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2020 by Cisco Systems, Inc.
Compiled Tue 04-Feb-20 14:05 by prod_rel_team
ROM: System Bootstrap, Version 12.2(50r)SYS3, RELEASE SOFTWARE (fc1)
cr-6513-sw1 uptime is 1 week, 1 day, 3 hours, 37 minutes
Uptime for this control processor is 1 week, 1 day, 3 hours, 38 minutes
System returned to ROM by power on
System restarted at 04:29:08 PDT Sun Oct 23 2022
System image file is "bootdisk:s2t54-ipservicesk9-mz.SPA.155-1.SY5.bin"
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6513-E (M8572) processor (revision ) with 1785856K/262144K bytes of memory.
Processor board ID FOX1553GTT6
CPU: MPC8572_E, Version: 2.2, (0x80E80022)
CORE: E500, Version: 3.0, (0x80210030)
CPU:1500MHz, CCB:600MHz, DDR:600MHz
L1: D-cache 32 kB enabled
I-cache 32 kB enabled
Last reset from power-on
30 Virtual Ethernet interfaces
339 Gigabit Ethernet interfaces
9 Ten Gigabit Ethernet interfaces
2543K bytes of non-volatile configuration memory.
10-31-2022 09:41 AM
- You may try latest advisory release : https://software.cisco.com/download/home/283933147/type/280805680/release/15.5.1-SY8 , check if that can help.
M.
10-31-2022 09:48 AM
Thank you Marce1000 , indeed I will download and upgrade the IOS and see if that helps, It might take few days as I have to do it during small blanket window.
Also I notice I have a few VMs that are hammering me with broadcast, I am trying to turn them off until I find a fix for it.
