Cisco 7301 Buffer Underruns
weathermon
Community Member
Hi all,
I've got a strange one that I'm pulling my hair out trying to work out.  We've got a Cisco 7301 connected to a 3750 that's showing a lot of buffer underruns when transmitting to the 3750.
The 7301's config is as follows:
interface GigabitEthernet0/2
 description Gi0/2 Trunk
 mtu 1600
 no ip address
 load-interval 30
 media-type rj45
 speed auto
 duplex auto
 negotiation auto
 hold-queue 1024 in
 hold-queue 1024 out
end
The 3750's config is as follows:
interface GigabitEthernet1/0/4
 description Gi1/0/4 CORE-Gi0/2
 switchport mode trunk
 hold-queue 1024 in
 hold-queue 1024 out
end
Here's the output from Gi0/2 on the 7301:
GigabitEthernet0/2 is up, line protocol is up
  Hardware is BCM1250 Internal MAC, address is  xxxxxxxxxxxx
  Description: Gi0/2 Trunk
  MTU 1600 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 245/255, txload 3/255, rxload 7/255
  Encapsulation 802.1Q Virtual LAN, Vlan ID  1., loopback not set
  Keepalive set (10 sec)
  Full Duplex, 1000Mbps, media type is RJ45
  output flow-control is XON, input flow-control is XON
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 01:05:55
  Input queue: 0/1024/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/1024 (size/max)
  30 second input rate 27546000 bits/sec, 4091 packets/sec
  30 second output rate 12483000 bits/sec, 3398 packets/sec
     16912174 packets input, 1720623525 bytes, 0 no buffer
     Received 14168 broadcasts (0 IP multicasts)
     0 watchdog, 91077 multicast, 0 pause input
     14743902 packets output, 2948242260 bytes, 1223851 underruns
     1223851 output errors, 0 collisions, 0 interface resets
     0 lost carrier, 0 no carrier, 0 pause output
And on the 3750:
GigabitEthernet1/0/4 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is xxxxxxxxxxxxxxxx
  Description: Gi1/0/4 CORE-Gi0/2
  MTU 2000 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 241/255, txload 7/255, rxload 3/255
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:31, output 00:00:00, output hang never
  Last clearing of "show interface" counters 00:54:33
  5 minute input rate 11807000 bits/sec, 2301 packets/sec
  5 minute output rate 27530000 bits/sec, 3988 packets/sec
     9186933 packets input, 1829460673 bytes, 0 no buffer
     Received 64 broadcasts (0 multicast)
     1187716 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 60 multicast, 0 pause input
     14223320 packets output, 3655786359 bytes, 0 underruns
When I clear counters, I see the error rate at around 3-400 underruns per second.. Here's a graph showing traffic and errors associated with that port.  There's not an overly large amount of traffic present so I don't think it's a buffer issue.
The 7301 is running c7301-adventerprisek9-mz.122-33.SRC5.bin and the 3750 is running c3750-ipbase-mz.122-25.SEE3.bin
Cheers, Mike
Mark Malone
Have you tried changing the cable out between the 2 switches reliability is down on both sides can indicate layer 1 issues 245/255
one side is configured as a trunk but the other side looks to be set as access layer , i would set the configuration as 1 or the other
Your mtu is different on both sides as well , are you using SAN/VMware locally ?
