Bookmark
Subscribe
1255
Cisco 9300 power supply installation while powered on
adeebtaqui
Level 4
Level 4
Wanted to know if we can install 2nd power supply in Catalyst Switches while switch is on or should we power of switch
marce1000
  - Shouldn't be a problem , check the logs on the 9300 when doing that (just after) ,
 M.
M02@rt37
Hello @adeebtaqui,
The power supply is hot-swappable.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/hardware/install/b_c9300_hig/m_9300_installing_a_power_supply.html
Best regards
Leo Laohoo
As long as the new power supply is NOT powered, it is fine.
