Cisco 9330 gateway for ip phone vlan
mostafa-parsaee
Hello All
I have a cisco 3850 switch used for Distribute Layer.
All Vlan and interface vlan are defined in this switch. Involved:
vlan 80 name PC-vlan
vlan 81 name IP-Phone vlan
interface vlan 80
ip addr x.x.x.x x.x.x.x
ip helper address x.x.x.x
In layer 2: we use Access switch 9200L or 2960x.and users connected to this switch ports. And PCs and ip-phones go to dhcp server and get ip from dhcp and work normally.
NOW: I config new cisco switch: 9300x-24Y for my distribution layer exactly same as 3850 configuration.(All vlans and interface vlans and other configs are same).
when replace the new switch in DSW layer, All PCs are ok, BUT ip-phones can not get IP from DHCP server.
I rollback to old DSW switch and IP-phones got IP and work normally, but with new 9300 DSW switch not work.
some other info may be helpful:
int gi0/1( trunk port):
switchport trunk native vlan 999
switchport trunk allowed vlan 80-81
switchport mode trunk
switchport nonegotiate
ip arp inspection trust
ip dhcp snooping trust
vtp version: 3
no vtp password
DSW switch: vtp primary
access switch: vtp transparent
ASW switch: ip arp inspection, ip dhcp snopping, port security
Ip phones : Mitel 5212
Please Help me. Is there any config needed to Switch 9300 or Access switches for resolve this problem?
38 Replies 38
mostafa-parsaee
excuse for miss spelling:
Cisco 9300 gateway for ip phone vlan
@mostafa-parsaee
 It should work. If you mirrored the configuration really dont see why not.
The only way to figure this out is take the config from both switch and use a program like CompareIt in order to make sure you did not miss anything.
 Rather than that would be install the 9300 and troubleshoot.
Mark Elsen
  - For the time being could you try with not using these configuration commands on int  gi0/1 :
                 And check if that can help (?)
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Thanks for Reply,
I tested but not work.
Is your DHCP server on a separate network? If so, how do your phones know where to get an IP address and subsequently their TFTP settings for call manager? You will need a helper address on their Default Gateway VLAN interface for your phones to reach the resources they need.
Are you able to provide the full config of the 9300 and the 3850?
-David
The DHCP server is My PDC-ADC and is in local Network.
Interface vlan is defined on DSW switch Like this:
interface vlan 81
description default-gateway for IP-Phones
ip helper-address 172.10.0.1
ip helper-address 172.10.0.2
These 2 Servers Are DHCp servers which Have scopes for ip phones.
mostafa-parsaee
3850 Config:
version 16.12
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps log datetime localtime
service password-encryption
service compress-config
service sequence-numbers
service call-home
platform punt-keepalive disable-kernel-core
vrf definition Mgmt-vrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
logging buffered 8192 informational
logging console critical
logging monitor informational
aaa session-id common
switch 1 provision ws-c3850-12s
no ip source-route
ip routing
ip name-server 172.10.0.1 172.10.0.2
no ip domain lookup
ip domain name xxxx
login block-for 30 attempts 3 within 10
login delay 3
login on-failure log every 3
login on-success log
udld aggressive
no device-tracking logging theft
license boot level ipservicesk9
diagnostic bootup level minimal
spanning-tree mode rapid-pvst
spanning-tree portfast bpduguard default
spanning-tree vlan 1-4094 priority 24576
memory reserve critical 1000
memory free low-watermark processor 79502
errdisable recovery cause all
redundancy
mode sso
transceiver type all
monitoring
hw-switch switch 1 logging onboard message
no cdp run
class-map match-any system-cpp-police-topology-control
description Topology control
class-map match-any system-cpp-police-sw-forward
description Sw forwarding, L2 LVX data, LOGGING
class-map match-any system-cpp-default
description EWLC control, EWLC data, Inter FED
class-map match-any system-cpp-police-sys-data
description Learning cache ovfl, High Rate App, Exception, EGR Exception, NFL SAMPLED DATA, RPF Failed
class-map match-any system-cpp-police-punt-webauth
description Punt Webauth
class-map match-any system-cpp-police-l2lvx-control
description L2 LVX control packets
class-map match-any system-cpp-police-forus
description Forus Address resolution and Forus traffic
class-map match-any system-cpp-police-multicast-end-station
description MCAST END STATION
description Transit Traffic and MCAST Data
class-map match-any system-cpp-police-l2-control
description L2 control
class-map match-any system-cpp-police-dot1x-auth
description DOT1X Auth
class-map match-any system-cpp-police-data
description ICMP redirect, ICMP_GEN and BROADCAST
class-map match-any system-cpp-police-stackwise-virt-control
description Stackwise Virtual
class-map match-any non-client-nrt-class
class-map match-any system-cpp-police-routing-control
description Routing control and Low Latency
class-map match-any system-cpp-police-protocol-snooping
description Protocol snooping
class-map match-any system-cpp-police-dhcp-snooping
description DHCP snooping
class-map match-any system-cpp-police-system-critical
description System Critical and Gold Pkt
policy-map system-cpp-policy
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
no ip address
shutdown
negotiation auto
interface GigabitEthernet1/1/3
description Link to CSW-A01
no switchport
ip address xxxx xxxx
ip ospf priority 0
interface GigabitEthernet1/1/4
description Link to CSW-A02
no switchport
ip ospf priority 0
interface GigabitEthernet1/0/1
switchport trunk allowed vlan 80-83
logging event trunk-status
interface Vlan1
no ip address
shutdown
interface Vlan80
description Computer Default-Gateway
interface Vlan81
description IPPhone Default-Gateway
interface Vlan82
description CCTV Default-Gateway
no ip address
shutdown
interface Vlan83
description Printer Default-Gateway
ip forward-protocol nd
no ip http server
ip http authentication local
no ip http secure-server
ip ssh time-out 60
ip ssh version 2
ip ssh server algorithm encryption aes128-cbc aes128-ctr aes192-cbc aes192-ctr aes256-cbc aes256-ctr 3des-cbc
logging trap critical
control-plane
service-policy input system-cpp-policy
ntp server xxxx
end
9300 config:
version 17.9
hostname my-switch
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
switch 1 provision c9300x-24y
ip routing
no ip domain lookup
ip domain name xxxx
login delay 3
login quiet-mode access-class MANAGEMENT
udld aggressive
vtp version 3
license boot level network-advantage addon dna-advantage
license smart transport callhome
memory free low-watermark processor 131040
redundancy
mode sso
crypto engine compliance shield disable
monitoring
class-map match-any system-cpp-police-ewlc-control
description EWLC Control
description Sw forwarding, L2 LVX data packets, LOGGING, Transit Traffic
description EWLC Data, Inter FED Traffic
description Openflow, Exception, EGR Exception, NFL Sampled Data, RPF Failed
class-map match-any system-cpp-police-high-rate-app
description High Rate Applications
description MCAST Data
description Stackwise Virtual OOB
class-map match-any system-cpp-police-ios-routing
description L2 control, Topology control, Routing control, Low Latency
class-map match-any system-cpp-police-ios-feature
description ICMPGEN,BROADCAST,ICMP,L2LVXCntrl,ProtoSnoop,PuntWebauth,MCASTData,Transit,DOT1XAuth,Swfwd,LOGGING,L2LVXData,ForusTraffic,ForusARP,McastEndStn,Openflow,Exception,EGRExcption,NflSampled,RpfFailed
ip dhcp client client-id ascii FVH2823L0PT
ip address dhcp
negotiation auto
interface TwentyFiveGigE1/0/1
no switchport
ip address xxxx
ip ospf priority 0
interface TwentyFiveGigE1/0/2
no switchport
ip address xxxx
ip ospf priority 0
interface TwentyFiveGigE1/0/10
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan80
interface Vlan81
interface Vlan82
no ip address
shutdown
interface Vlan83
no ip http server
ip ssh time-out 60
ip ssh version 2
logging host xxxx
control-plane
exception crashinfo maximum files 20
end
Do you have VLAN created both the sides (i do not see in the config) by adding interface does not mean vlan created - can you post show span vlan 80 / 81 /999 (from both Access and DSW side)
Testing :
1. both the side change native VLAN from 999 to 80 and test it
2. can you connect same Phone to cat 9300 - is that works ?
BB
Thanks for Reply.
Yes, vlan 80-81 are created in DSW switch. And ASW switch Get them as a vtp client.
1-I tested it but not work.
2-I don't want to connect IP-Phone to 9300 switch. This switch is distribute switch. The phone connected to ASW.
but however, can not connect any same Phone(Mitel 5212) to ASW.Just New model Mitel 5312 Tested Ok.
vtp version 3 has no password.Maybe related to Issue?
both of Links are not same.DSW side is 10/25G and ASW is 1G.Maybe related to Issue?
We have seen some issue like this with old Phones, if the new phone working, check the Options in the DHCP. that where all pointing to the issue, there is nothing to do with VTP here, as long as other phone working.
make sure DHCP Options for old and new phone are added
run the debug and also provide one of the ASW configuration what model of the switch ?
BB
Thanks For Reply.
The DHCP option for IP-Phones:
125 Mitel: id:ipphone.mitel.com; sw_tftp=x.x.x.x ; call_srv=x.x.x.x dscp=56
And it is working for Mitel 5212 when 3850 switch is the DSW switch. BUT not work when 9300 switch is the DSW. And Mitel5312 works when New 9300 switch is DSW switch.
Which option should config for this Issue?
Here Is Config for ASW-switch:
version 12.2
no service pad
service timestamps log datetime localtime year
no service dhcp
hostname xxx
boot-start-marker
boot-end-marker
aaa new-model
clock timezone IRAN 3 30
system mtu routing 1500
vtp domain xxxx
vtp mode transparent
udld aggressive
no ip source-route
no ip domain-lookup
ip domain-name xxxx
ip name-server 172.10.0.2
ip dhcp snooping vlan 80-83
no ip dhcp snooping information option
ip dhcp snooping
ip arp inspection vlan 80-83
spanning-tree portfast default
spanning-tree portfast bpdufilter default
vlan internal allocation policy ascending
vlan dot1q tag native
vlan 80
name computers
vlan 81
name IP-Phones
vlan 82
name CCTV
vlan 83
name Printers
vlan 400
name RSPAN
remote-span
vlan 900
name UseLess
vlan 999
name AntiVLANhopping
ip ssh time-out 60
ip ssh version 2
ip scp server enable
interface GigabitEthernet0/1
switchport access vlan 80
switchport mode access
switchport voice vlan 81
switchport block multicast
switchport block unicast
switchport port-security
switchport port-security max 2
switchport port-security aging time 1440
switchport port-security violation restrict
switchport port-security aging type inactivity
switchport port-security mac-address sticky
ip arp inspection limit rate 100
storm-control broadcast level bps 2m 1.5m
storm-control action trap
no lldp transmit
no lldp receive
spanning-tree bpduguard enable
spanning-tree guard root
ip verify source port-security
ip dhcp snooping limit rate 100
interface GigabitEthernet0/49
interface Vlan1
no ip address
no ip route-cache
no ip mroute-cache
shutdown
no ip classless
no ip http server
no vstack
exception memory ignore overflow processor
exception memory ignore overflow io
ntp clock-period 36028922
ntp source Vlan7
ntp server xxxx
mac address-table notification change
mac address-table notification mac-move
mac address-table notification threshold
end
Your DSW - ASW trunk appears rather inconsistent as for the native vlan (tagging). I can see "vlan dot1q tag native" at ASW but cannot see the command at the opposite side (DSW). Can you please set both sides identically and check if there is any progress.
Best regards,
Antonin
Since you have other phone working that means snooping ok i belive.
can you default one of the interface and make just simple configuration and test it :
interface x/x
switchport access vlan xx
switchport voice vlan yy
switchport port-security maximum 4
switchport port-security aging time 5
no logging event link-status
no cdp enable
BB
Thank you for the extra info. I don't see anything wrong with the config initially. Can you supply a drawing/map of how all the switches/phones are connected?
Also can you put a local DHCP configuration on the router (same as the other DHCP pool) for the phones to test if that works?
