Cisco BPDU with inconsistent peer
aacable79
I have few cisco classic series switches connected with each other via trunk port config. Having port inconsistency issue at one departmental switch with Core switch. Requesting for some assistance to sort the issue
At core switch I see inconsistency errors for port connected with one particular departmental switch
  • Core Switch > 3850
  • Department problematic Switch > 3650
on Core Switch uplink going to department switch is
interface TenGigabitEthernet1/0/13
description Trunk_Going_2_Deartment_SW
switchport mode trunk
on Department switch trunk port going to core switch
interface TenGigabitEthernet1/1/3
description Trunk_UPlink_Going_to_Core_SW
  • Both Switch is in rapid-pvst mode
on Core Switch , I see errors for the trunk port (connected with departmental switch)
614212: Mar 14 09:11:23: %SPANTREE-2-RECV_PVID_ERR: Received BPDU with inconsistent peer vlan id 9 on TenGigabitEthernet1/0/13 VLAN1.
614213: Mar 14 09:11:23: %SPANTREE-2-BLOCK_PVID_PEER: Blocking TenGigabitEthernet1/0/13 on VLAN0009. Inconsistent peer vlan.
614214: Mar 14 09:11:23: %SPANTREE-2-BLOCK_PVID_LOCAL: Blocking TenGigabitEthernet1/0/13 on VLAN0001. Inconsistent local vlan.
614215: Mar 14 09:11:23: %SPANTREE-2-BLOCK_PVID_PEER: Blocking TenGigabitEthernet1/0/13 on VLAN0024. Inconsistent peer vlan.
614216: Mar 14 09:11:23: %SPANTREE-2-BLOCK_PVID_PEER: Blocking TenGigabitEthernet1/0/13 on VLAN0030. Inconsistent peer vlan.
614217: Mar 14 09:11:23: %SPANTREE-2-BLOCK_PVID_PEER: Blocking TenGigabitEthernet1/0/13 on VLAN0040. Inconsistent peer vlan.
614218: Mar 14 09:11:23: %SPANTREE-2-BLOCK_PVID_PEER: Blocking TenGigabitEthernet1/0/13 on VLAN0099. Inconsistent peer vlan.
On Core Switch - Spanning Tree
Core_SW#sh spanning-tree
VLAN0001
  Spanning tree enabled protocol rstp
             This bridge is the root
VLAN0009
VLAN0024
VLAN0030
VLAN0040
VLAN0099
On Core Switch - Int Trunk
Text
On CORE Switch - INT TRUNK config
CORE_SW#sh int trunk
Port        Mode             Encapsulation  Status        Native vlan
Te1/0/1     on               802.1q         trunking      1
Te1/0/2     on               802.1q         trunking      1
Te1/0/3     on               802.1q         trunking      1
Te1/0/4     on               802.1q         trunking      1
Te1/0/6     on               802.1q         trunking      1
Te1/0/7     on               802.1q         trunking      1
Te1/0/8     on               802.1q         trunking      1
Te1/0/9     on               802.1q         trunking      1
Te1/0/11    on               802.1q         trunking      1
Te1/0/13    on               802.1q         trunking      1
Te1/0/16    on               802.1q         trunking      1
Te1/0/20    on               802.1q         trunking      1
Te1/0/21    on               802.1q         trunking      1
Te1/0/22    on               802.1q         trunking      1
Gi2/0/9     on               802.1q         trunking      1
Gi2/0/10    on               802.1q         trunking      1
Gi2/0/11    on               802.1q         trunking      1
Gi2/0/13    on               802.1q         trunking      1
Gi2/0/14    on               802.1q         trunking      1
Gi2/0/24    on               802.1q         trunking      1
Gi2/1/2     on               802.1q         trunking      1
Gi2/1/3     on               802.1q         trunking      1
Gi3/0/1     on               802.1q         trunking      1
Gi3/0/4     on               802.1q         trunking      1
Gi3/0/8     on               802.1q         trunking      1
Gi3/0/19    on               802.1q         trunking      1
Gi3/1/1     on               802.1q         trunking      1
Gi3/1/2     on               802.1q         trunking      1
Port        Vlans allowed on trunk
Te1/0/1     1-4094
Te1/0/2     1-4094
Te1/0/3     1-4094
Te1/0/4     1-4094
Te1/0/6     1-4094
Te1/0/7     1-4094
Te1/0/8     1-4094
Te1/0/9     1-4094
Te1/0/11    1-4094
Te1/0/13    1,9,24,30,40,99
Te1/0/16    1-4094
Te1/0/20    1-4094
Te1/0/21    1-4094
Te1/0/22    1-4094
Gi2/0/9     1-4094
Gi2/0/10    1-4094
Gi2/0/11    1-4094
Gi2/0/13    1-4094
Gi2/0/14    1-4094
Gi2/0/24    1-4094
Gi2/1/2     1-4094
Gi2/1/3     1-4094
Gi3/0/1     1-4094
Gi3/0/4     1-4094
Gi3/0/8     1-4094
Gi3/0/19    1-4094
Gi3/1/1     1-4094
Gi3/1/2     1-4094
Port        Vlans allowed and active in management domain
Te1/0/1     1-2,4,8-24,26,30,40,99
Te1/0/2     1-2,4,8-24,26,30,40,99
Te1/0/3     1-2,4,8-24,26,30,40,99
Te1/0/4     1-2,4,8-24,26,30,40,99
Te1/0/6     1-2,4,8-24,26,30,40,99
Te1/0/7     1-2,4,8-24,26,30,40,99
Te1/0/8     1-2,4,8-24,26,30,40,99
Te1/0/9     1-2,4,8-24,26,30,40,99
Te1/0/11    1-2,4,8-24,26,30,40,99
Te1/0/16    1-2,4,8-24,26,30,40,99
Te1/0/20    1-2,4,8-24,26,30,40,99
Te1/0/21    1-2,4,8-24,26,30,40,99
Te1/0/22    1-2,4,8-24,26,30,40,99
Gi2/0/9     1-2,4,8-24,26,30,40,99
Gi2/0/10    1-2,4,8-24,26,30,40,99
Gi2/0/11    1-2,4,8-24,26,30,40,99
Gi2/0/13    1-2,4,8-24,26,30,40,99
Gi2/0/14    1-2,4,8-24,26,30,40,99
Gi2/0/24    1-2,4,8-24,26,30,40,99
Gi2/1/2     1-2,4,8-24,26,30,40,99
Gi2/1/3     1-2,4,8-24,26,30,40,99
Gi3/0/1     1-2,4,8-24,26,30,40,99
Gi3/0/4     1-2,4,8-24,26,30,40,99
Gi3/0/8     1-2,4,8-24,26,30,40,99
Gi3/0/19    1-2,4,8-24,26,30,40,99
Gi3/1/1     1-2,4,8-24,26,30,40,99
Gi3/1/2     1-2,4,8-24,26,30,40,99
Port        Vlans in spanning tree forwarding state and not pruned
On Core Switch - VLAN Config
Text
CORE_SW#sh vlan
VLAN Name                             Status    Ports
1    default                          active    Te1/0/5, Te1/0/10, Te1/0/12, Te1/0/14, Te1/0/15, Te1/0/17, Te1/0/18, Te1/0/19, Te1/0/23, Te1/0/24, Gi2/0/1
                                                Gi2/0/3, Gi2/0/4, Gi2/0/5, Gi2/0/6, Gi2/0/7, Gi2/0/8, Gi2/0/12, Gi2/0/15, Gi2/0/16, Gi2/0/17, Gi2/0/18
                                                Gi2/0/19, Gi2/0/20, Gi2/0/21, Gi2/0/22, Gi2/0/23, Gi2/1/1, Gi2/1/4, Gi3/0/2, Gi3/0/3, Gi3/0/5, Gi3/0/6
                                                Gi3/0/7, Gi3/0/9, Gi3/0/10, Gi3/0/11, Gi3/0/12, Gi3/0/13, Gi3/0/15, Gi3/0/16, Gi3/0/17, Gi3/0/18, Gi3/0/20
                                                Gi3/0/21, Gi3/0/22, Gi3/0/23, Gi3/0/24, Gi3/1/3, Gi3/1/4
9    WIFI_MGMT-VLAN                   active    Gi3/0/14
30   ABC-CORP_WIFI                    active
40   ABC-GUEST_WIFI                   active
99   ABC-MGMT-VLAN                    active
On Departmental Switch - VLAN config
Text
Department_SW#sh vlan
1    default                          active    Gi1/0/1, Gi1/0/2, Gi1/0/3, Gi1/0/4, Gi1/0/5, Gi1/0/6, Gi1/0/7, Gi1/0/8, Gi1/0/10, Gi1/0/11, Gi1/0/12
                                                Gi1/0/13, Gi1/0/14, Gi1/0/15, Gi1/0/16, Gi1/0/17, Gi1/0/18, Gi1/0/19, Gi1/0/20, Gi1/0/21, Gi1/0/22, Gi1/0/23
                                                Gi1/0/24, Gi1/0/25, Gi1/0/26, Gi1/0/27, Gi1/0/28, Gi1/0/29, Gi1/0/30, Gi1/0/31, Gi1/0/32, Gi1/0/33, Gi1/0/34
                                                Gi1/0/35, Gi1/0/36, Gi1/0/37, Gi1/0/38, Gi1/0/39, Gi1/0/40, Gi1/0/42, Gi1/0/43, Gi1/0/44, Gi1/0/45, Gi1/0/47
                                                Gi1/0/48, Gi1/1/1, Gi1/1/2, Te1/1/4
9    vlan9_wifi_mgt                   active
24   vlan24_wifi                      active
On Department Switch - INT TRUNK config
Text
P1_WAREHOUSE-SW-1.3#sh int trunk
Gi1/0/9     on               802.1q         trunking      1
Gi1/0/41    on               802.1q         trunking      1
Gi1/0/46    on               802.1q         trunking      1
Te1/1/3     on               802.1q         trunking      1
Gi1/0/9     1-4094
Gi1/0/41    1-4094
Gi1/0/46    1-4094
Te1/1/3     1,9,24,30,40,99
Gi1/0/9     1,9,24,30,40,99
Gi1/0/41    1,9,24,30,40,99
Gi1/0/46    1,9,24,30,40,99
8 Replies 8
Mark Elsen
        - FYIhttps://bst.cloudapps.cisco.com/bugsearch/bug/CSCvh56485
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
balaji.bandi
First i would check, is the VTP running on both side as Server, if so make VTP transparent both the sides (if you do not need VTP here)
show vtp  - provide you information.
 can you post below information : (in text file attachement)
show span summary
show span root
show spann details
BB
aacable79
Output from Core + Department switch is attached. Kindly review if it helps.
CORE Switch running as VTP Server and Branch running as Transparent.
If you do not need VTP Server, Disable to Transparent.
CORE Switch has different VLAN compare to Branch. try below config and let us know is that fix the issue ?
witchport trunk allowed vlan 1,9,24,30,40,99 switchport mode trunk
BB
you run in one SW RSTP and in other you run R-PVST
these are complete two different STP mode
so you must change from RSTP to R-PVST
aacable79
Unfortunately this morning (before reading this thread), we tried to upgrade the switch firmware as one of other proposed solution, but during upgrade process it got hung & upon rebooting switch became unresponsive at all.
We have replaced the unit with backup switch. Now we are trying to recover the switch & if it works, we will try the VTP transparent at both ends along with suggested cmd's. Thank you very much for the information & I will update this thread soon.
Sure - let us know the outcome.
I may be glared looking the text file, i see both running same  - where do we see different STP modes here ?
CORE_SW#show span summary
DEPARTMENT_SW#show span summary
BB
VLAN0001
I think this Q for me,
sure the summary show R-PVST but for each VLAN I see the mode is RSTP.
