Cisco Catalyst 9200 down grade problem
w11dgod
Visitor
Hi everyone! I had a problem while I was trying to downgrade my c9200 from 17.09.04 to 17.06.05, it displayed a weeor message:
install_add: Adding IMG
[1] Switch 1 FAILED: /mnt/sd3/user requires 514791 KB of free space, but only 266332 KB is available
FAILED: add_activate_commit /mnt/sd3/user/cat9k_lite_iosxe.17.06.05.SPA.bin Wed Nov 08 05:13:06 UTC 2023
After confirming I know that 17.09.04's files are in use and using a lot of space of the flash, so I'm wondering is it possible to deactive these files first and then remove them so that I can proceed to downgrade with the 17.06.05's file?
DanielP211
Hello!
The 9200 should have more than enough space to facilitate both images + install .pkg's. So check the bootflash for any older images. You can also use install remove inactive to delete unused images and .pkg's. The command may also remove the 17.6.5 from flash so you might have to copy it again.
BR
****Kindly rate all useful posts*****
Leo Laohoo
Post the complete output to the command "dir".
DanielP211
Hello!
BR
w11dgod
Visitor
Thank you all for the reply and the assistance somehow I found a way to solve this!
By default the IOS version was 17.09.04, I changed the boot variable into 17.06.05's bin file, then proceeded with the downgrade instructions then the device successfully downgraded to 17.06.05
Hi, I ran into this problem yesterday with multiple C9200L-24P-4X switches.
I overcame this by deleting all .pkg and .bin files from the flash and installing the new image from USB, without copying the .bin file to the switch's flash.
