Cisco catalyst 9500-48Y4C
069521139
Does cisco catalyst 9500-48y4c support stack wise virtual?
If it dose not support ,Which solution cisco recommend?
Wongsakorn,
22 Replies 22
Ming_Prince
Yes it is supported from 16.10.x:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9500/software/release/16-10/configuration_guide/ha/b_1610_ha_9500_cg/configuring_cisco_stackwise_virtual.html
Cisco StackWise Virtual is supported on the following models:
Cisco Catalyst 9500 Series Switches
Cisco Catalyst 9500 Series High Performance Switches
C9500-24Q
C9500-32C
C9500-12Q
C9500-32QC
C9500-40X
C9500-24Y4C
C9500-16X
C9500-48Y4C
Table 1. Switches supporting StackWise Virtual
I have two Catalyst 9500-48Y4C with IOSXE Version 16.11.1. According to Release Notes Stackwise-Virtual should be supported.
But I even cannot run the commands to enable it ("stackwise-virtual").
At the moment the license is not activated yet and still in EVALUATION state.
Could this be the problem? Will it be possible to enable stackwise-virtual with an activated license? Or do I have to update to 16.12.1. ?
Thanks for help
Stefan
are you running DNA Essentials or Advantage eval licences?
  Network Advantage is needed for stack wise virtual
you can try :
license boot level network-advantage
to activate eval license for advantage
Rwesel,
Stackwise Virtual requires DNA-Advantage licensing
. Table 1 & Table 2 Depending on your platform but the information is the same.
https://www.cisco.com/c/dam/en/us/products/collateral/switches/catalyst-9000/nb-06-cat-9k-stack-wp-cte-en.pdf
abeebvm
Still 6th April 2020 document also not included 9500-48Y4C-A is not showing virtual stack wise.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9500/software/release/16-9/configuration_guide/ha/b_169_ha_9500_cg/configuring_cisco_stackwise_virtual.html#concept_jwp_vxx_31b
Is there any update on this for virtual stack wise. Or can you please suggest another recommended solution instead of this virtual stackwise.
Depends on the firmware loaded.
Please read Configuring Cisco StackWise Virtual (IOS-XE version 16.12.X) and go to the Cisco StackWise Virtual on Cisco Catalyst 9500 Series Switches section.
Thank You for your prompt response. I am going to use 40G for stackwise. Can Use 10G for dual active connection.
