Cisco Catalyst 9800 series with 10000 APs
Ahmed Gamal
I have 10,000 access points, and I need a wireless controller that supports this number, as the 9800-80 supports only 6,000, so please suggest a solution for me.
10 Replies 10
Leo Laohoo
Get two 9800-80 and put 5k in each.
Do not make any attempts to put >5k per WLC.
I check this yesterday
Wlc 9800-cl support more than 10000.
Check data of it.
MHM
No , what I know the maximum number for large option is 6000 APs
Correct' it support up to 6000 and client up to 64000.
MHM
You need to config N+1 wlc then
Put 5000 in each WLC and select which AP can fallback to other wlc (5000 ap in one wlc can not all fallback to other wlc).
MHM
yes that is correct Cisco do not have any model support more than 6K AP (may be confusing here client vs AP)
so AP Limitation we are clear, so you need make a deployment method as suggested more WLC controller with roaming to fix for now.
BB
My opinion is to provide four wireless LAN controllers (9800–80), and as I have two datacenters
I will put each SSO HA in the two datacenters (the first cluster, the active WLC, in the first DC, and the standby will be in the second DC, and the other cluster will be vice versa), but I need to clarify what's the situation of the interference between the different WLC clusters and the APs. Could you please explain more about the roaming between the different wireless clusters?
You plan a such a way building wise to be part of DC1 WLC and some building DC2 so on
as suggested make sure you plan correctly - since this is very high deployment, contact right partner for you to do survey and optimal deployment to get better outcome.
BB
WLC HA SSO is different than N+1
The SSO you can not load balance between two WLC
In N+1 you can do that
So with SSO even two WLC you will still have 6000 AP.
Check this note
MHM
