Cisco Nexus 40G to 1G
omer shtivi
We have N9K-C93108TC-EX (48 ports Copper and 6 ports QSFP)
We want to connect a FW using 1G optics so we need to "lower" the speed of the 40G.
So we bought CVR-QSFP-SFP10G and we put a Multi-mode SFP We did the breakout command:
interface breakout module 1 port 49-50 map 10g-4x
but when I issue speed 1000 we receive the following:
Ethernet1/50/1 is down (Transceiver speed does not match the speed configured on the port)
We are using version:
7.0(3)I4(7)
Does anyone knows how do I do it?
BR,
Omer Shtivi
8 Replies 8
Reza Sharifi
The Optics you are using are 10G 10x4=40 and not 1Gig SFP.  I don't think there is a way to break down a 40Gig interface to 40x1Gig interfaces. I have not seen that.
Don't need 40 1G, need 1G.
Found out its a version most probably, https://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/GE_Tx_Matrix.html#_Toc508962836
So upgrading now:
NXOS-703I7.1
I understand you need only 1 1Gig but the breakout cable is only 10Gig.
Is this the optic you are using for 1Gig?
GLC-SX-MMD
Yes, I'm using
GLC-SX-MMD
Works
Great. So, NXOS-703I7.1 works for using 1Gig with a breakout cable.  Does the interface numbering stay the same as 10G?
Guys, Can we use 6*40G as Access port..
as I am working on a requirement where I have to connect the 10G Storage NAS Box hence I have proposed CVR-QSFP-SFP10G with SFP-10G-SR and i want to use as Access port with specific VLAN assigned to it...
But I come to know the 6*40G in Nexus 93108/93180 can be only use for uplink purpose as Trunk ...not as Access port...please suggest bit urgent...?
I understood that he isn't using a breakout cable, because he mentioned CVR-QSFP-SFP10G adapter.
So the interface of the switch was physically converted from 40G to 10G and he can be using a OM3/OM4 fiber or single mode fiber.
Even with the QSFP to 10G SFP adapter, is it necessary to input the breakout command?
