Cisco Stack etherchannel configuration: flag stuck in stand-alone
sdemediuk
I am trying to set up an etherchannel for my Cisco Stack (2x 3750G Catalyst Switches), with one port on each switch in the etherchannel. Using the Cross stack example http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a00806cb982.shtml as a guide I created my channel. However when i view "show etherchannel 6 summary" its says that both my ports are in stand-alone, when i want them to be in the bundled in port-channel. Thank you in advance for the your help, I have added all the information I could think of.
Here is how I created the etherchannel
sail-sw-1#conf t
sail-sw-1(config)#interface gigabiteethernet 1/0/10
sail-sw-1(config-if)#channel-group 6 mode active
sail-sw-1(config-if)#switchport trunk encapsulation dot1q
sail-sw-1(config-if)#switchport mode trunk
sail-sw-1(config-if)#exit
sail-sw-1(config)#exit
The running-config
sail-sw-1#show running-config
Building configuration...
Current configuration : 5390 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname sail-sw-1
boot-start-marker
boot-end-marker
enable secret 5 .....
macro global description cisco-global
no aaa new-model
switch 1 provision ws-c3750g-24ts
switch 2 provision ws-c3750g-24ts
system mtu routing 1500
udld aggressive
mls qos map cos-dscp 0 8 16 24 32 46 46 56
crypto pki trustpoint TP-self-signed-538118016
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-538118016
revocation-check none
rsakeypair TP-self-signed-538118016
crypto pki certificate chain TP-self-signed-538118016
certificate self-signed 01
  30.......
AF
  quit
errdisable recovery cause link-flap
errdisable recovery interval 60
port-channel load-balance src-dst-mac
spanning-tree mode rapid-pvst
spanning-tree loopguard default
no spanning-tree optimize bpdu transmission
vlan internal allocation policy ascending
interface Port-channel6
interface GigabitEthernet1/0/1
no mdix auto
interface GigabitEthernet1/0/2
no mdix auto
interface GigabitEthernet1/0/3
no mdix auto
interface GigabitEthernet1/0/4
no mdix auto
interface GigabitEthernet1/0/5
no mdix auto
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
no mdix auto
interface GigabitEthernet1/0/8
no mdix auto
interface GigabitEthernet1/0/9
no mdix auto
interface GigabitEthernet1/0/10
no mdix auto
interface GigabitEthernet1/0/11
no mdix auto
interface GigabitEthernet1/0/12
no mdix auto
interface GigabitEthernet1/0/13
no mdix auto
interface GigabitEthernet1/0/14
no mdix auto
interface GigabitEthernet1/0/15
no mdix auto
interface GigabitEthernet1/0/16
no mdix auto
interface GigabitEthernet1/0/17
no mdix auto
interface GigabitEthernet1/0/18
no mdix auto
interface GigabitEthernet1/0/19
no mdix auto
interface GigabitEthernet1/0/20
no mdix auto
interface GigabitEthernet1/0/21
no mdix auto
interface GigabitEthernet1/0/22
no mdix auto
interface GigabitEthernet1/0/23
no mdix auto
interface GigabitEthernet1/0/24
no mdix auto
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet2/0/1
no mdix auto
interface GigabitEthernet2/0/2
no mdix auto
interface GigabitEthernet2/0/3
no mdix auto
interface GigabitEthernet2/0/4
no mdix auto
interface GigabitEthernet2/0/5
no mdix auto
interface GigabitEthernet2/0/6
interface GigabitEthernet2/0/7
no mdix auto
interface GigabitEthernet2/0/8
no mdix auto
interface GigabitEthernet2/0/9
no mdix auto
interface GigabitEthernet2/0/10
no mdix auto
interface GigabitEthernet2/0/11
no mdix auto
interface GigabitEthernet2/0/12
no mdix auto
interface GigabitEthernet2/0/13
no mdix auto
interface GigabitEthernet2/0/14
no mdix auto
interface GigabitEthernet2/0/15
no mdix auto
interface GigabitEthernet2/0/16
no mdix auto
interface GigabitEthernet2/0/17
no mdix auto
interface GigabitEthernet2/0/18
no mdix auto
interface GigabitEthernet2/0/19
no mdix auto
interface GigabitEthernet2/0/20
no mdix auto
interface GigabitEthernet2/0/21
no mdix auto
interface GigabitEthernet2/0/22
no mdix auto
interface GigabitEthernet2/0/23
no mdix auto
interface GigabitEthernet2/0/24
no mdix auto
interface GigabitEthernet2/0/25
interface GigabitEthernet2/0/26
interface GigabitEthernet2/0/27
interface GigabitEthernet2/0/28
interface Vlan1
ip address 192.168.0.1 255.255.255.0
ip default-gateway 192.168.76.102
ip classless
ip http server
ip http secure-server
ip sla enable reaction-alerts
line con 0
line vty 0 4
password Mil19
login
line vty 5 15
password Mil19
login
end
Port-Channel 6 Interface
(according to the example there should be this line "Members in this channel: Gi1/0/10 Gi2/0/10")
sail-sw-1#show interfaces port-channel 6
Port-channel6 is down, line protocol is down (notconnect)
  Hardware is EtherChannel, address is 0000.0000.0000 (bia 0000.0000.0000)
  MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
  Keepalive set (10 sec)
  Auto-duplex, Auto-speed, link type is auto, media type is unknown
  input flow-control is off, output flow-control is unsupported
  Last input never, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
Etherchannel 6 Summary
sail-sw-1#show etherchannel 6 summary
Flags:  D - down        P - bundled in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      f - failed to allocate aggregator
        M - not in use, minimum links not met
        u - unsuitable for bundling
        w - waiting to be aggregated
        d - default port
Number of channel-groups in use: 1
Number of aggregators:           1
Group  Port-channel  Protocol    Ports
6      Po6(SD)         LACP      Gi1/0/10(I) Gi2/0/10(I)
It seems like the Linux box NIC teaming is not working properly. Please
check the Linux side.
NT
9 Replies 9
Nagaraja Thanthry
What is connected on the other end of the EtherChannel? Have you verified
that the other end is configured properly and is up?
NT
  Try using the interface range command on the two ports that are in the channel group ,  do a shut ,  then a no shut and see what happens .  If you try to bring the ports up one at a time funky things tend to happen in etherchannels.
Assuming the remote is configured correctly. When you add the port into the etherchannel, you shouldn't configure  trunking directly in the port, it should be done in the interface  port-channel 6. This is the sequence I usually do and it always work
interface g1/0/10
interface g1/0/20
jerry
as Jerry has already said, try to set up the Interface configuration first and then the interface portchannel configuration.
I did it on Tuesday in this way and it works probably.
Martin
sdemediuk
If nothing is connected/setup at the other end will that matter?
Why would having nothing there put them in standalone and not bundled in the port-channel?
sdemediuk
The connection i am using at the other end is a Linux box running CentOS 5.5 with 2 nics. I set it up by editing the rc.local script with these lines
modprobe bonding mode=4 miimon=100
ifconfig bond0 192.168.0.5 netmask 255.255.255.0
ifdown eth3
ifdown eth0
ifenslave eth3
ifenslave eth0
When I connect the linux box one of the ports on the swith changes mode from stand alone to bundled in port-channel. However the other one stays in stand alone.
The problem I am having is that when I ping another box connected to the switch on the same network it works fine. When I break one of the etherchannel links the pings continue like normal. The problem is when i reconnect the link, the pings stop for around 20-30 seconds, I get around 5 destination unreachable messages, and then it starts working again.
Ideally i want to be able to break any one of the two etherchannel links and the connection remains, and when the link is repaired I don't want my service interrupted while it figures out the link is back.
EDIT: I have tried setting up the way you suggested Jeye and still get the same results. I also tried the shutdown no shutdown trick bu with no luck.
Message was edited by: Simon Demediuk
NT
Is there an easy way to do this? As i have been through a bunch of guides and manuals which say that the mode 4 is the 802.3ad standard which in LACP. By setting up the ports on the switch as active that sets them up as LACP.
I found this from 06 where someone has had a similar problem, however there is no answer for it. Just a suggestion about primary and secondary modes. Could this be the cause?
https://supportforums.cisco.com/thread/29991
I would suggest starting with simple L2 EtherChannel. Set the switch side to
"mode on" and set the corresponding value on the Linux side. This will tell
you if the NIC teaming is working or not. Once you verify that, you can
introduce LACP.
NT
