Cisco WS-C2960-48PST-L , 802.3af
RS19
Level 4
Level 4
I am using Cisco Cisco WS-C2960-48PST-L  L2 switch
I am planning to Connect polycom phone VVX201 into the Cisco switch.
The polycom phone supports 802.3af
Does Cisco WS-C2960-48PST-L supports 802.3af ?
Francesco Molino
This switch supports 802.3af (POE).
It has 370 watts. Depending on your what class your devices are, you can connect few of them.
Here a link to help you see how many phones can be connected on this switch:
https://cpc.cloudapps.cisco.com/cpc/launch.jsp
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
balaji.bandi
WS-C2960-48PST-L - do support 802.3af.
Polycom phone VVX201 - guess need 15.4 - should be ok, depends on the number of phones you intend to connect to switch, make caluculation.
by issuing a command show power will give you power consumption.
BB
amikat
Polycom VVX201 is a IEEE 802.3af Class 2 device and as such you can connect this IP Phone to all 48 ports of the WS-C2960-48PST-L box which support 802.3af dynamic negotiation.
Best regards,
Antonin
