cisco WS-C6509
Kesar123456
My switch is having some problem.I am seeing all these.
Switch#show mod
Mod Ports Card Type Model Serial No.
1 2 Catalyst 6000 supervisor 2 (Active) WS-X6K-SUP2-2GE SAL0702BJLK
2 0 Supervisor-Other Unknown Unknown
Can i reset the second sup remotely using this command.
hw-module module 2 reset or
ask someone to pull the card physically(Hot swappable)
Does it have any impact on the switch.
Giuseppe Larosa
Hello Arun,
you can try to reload the module with
if this is not enough have someone to reseat the card but verify it is hot-swappable I always powered off the switch when dealing with supervisors
It looks like to be hot-swappable
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/hardware/Module_Installation/Mod_Install_Note/78_15767.html#wp51279
Hope to help
Giuseppe
All modules in a 6500 chassis are hot-swappable, including the supervisors. This is called online insertion and removal. There is a very small but real risk that there could be a switching bus stall when any module is inserted or removed and the system is in centralized forwarding mode.
