cisco3560
dkblee
hi! i got a cisco 3560 with compact flash card. how do i backup my statup config and ios image into the card?
Thanks.
6 Replies 6
ankbhasi
Hi Friend,
3560 is not a modular box and does not support any compact flash card and it has integrated flash on board.
You can take the backup of your IOS as well as config on tftp server.
Ankur
*Pls rate helpfull post
Hi!
Sorry for my mistake, it's a Cisco 2811 Router.
It has a external compact flash card. There's a card slot at the front panel. How do i backup to the compact flash.
Thanks.
Hi Friend,
Please go through the link below on using Compact flash cards on 2800 routers.
http://www.cisco.com/en/US/products/ps5854/prod_configuration_guide09186a00802c35d3.html
HTH,Please rate if it does.
-amit singh
hi!
how do i copy a file into a folder created in the flash card? it seems that it always copy to the root.
copy flash:
is the directory which is created in flash. If there is no directory, you have to copy files in root, else you can create a new directory in flash.
hope to help ... rate if it does ...
It will be
Copy tftp: flash:/config
If you want to create a new folder/directory, then use the command:
router#mkdir flash:/config
HTH,
-amit singh
