CISCO891W-AGN-A-K9, Max Wireless Transmission Speed
adil.nasser3
I have had trouble to verify the support wireless speed and band that CISCO891W-AGN-A-K9 supports.  I saw on a vendor website that it supports a max wireless transmission speed of 54Mbps but this seems low for what is supposed to be the current model wireless router which is supports 802.11n.
Can someone let me know what the maximum supported wireless speed and whether 5Ghz is supported?  Plus any additional information you can provided would be appreciated since I am thinking about purchasing it for my home wireless network (upgrading from an 871W).
Adil
paolo bevilacqua
Wrong forum, should post in "instrastructure - wireless". You can move your post using the actions panel on the right.
Anwyay:
http://www.cisco.com/en/US/prod/collateral/routers/ps380/data_sheet_c78-519930.html
Supports  802.11n speeds M0-15
http://en.wikipedia.org/wiki/IEEE_802.11n-2009#Data_rates
