config mode is locked cisco 4507
One of our Cisco 4507 is config mode is locked.
Power consumed by backplane : 40 Watts
Mod Ports Card Type Model Serial No.
1 48 10/100/1000BaseT (RJ45) WS-X4648-RJ45-E
2 24 1000BaseX (SFP) WS-X4624-SFP-E
3 4 Sup 7-E 10GE (SFP+), 1000BaseX (SFP) WS-X45-SUP7-E
4 Supervisor
5 24 1000BaseX (SFP) WS-X4624-SFP-E
M MAC addresses Hw Fw Sw Status
1 3c08.f604.8686 to 3c08.f604.86b5 2.1 Ok
2 24e9.b3e5.dbf4 to 24e9.b3e5.dc0b 2.0 Ok
3 3c08.f620.12c0 to 3c08.f620.12c3 2.1 15.0(1r)SG5 03.04.02.SG Ok
4 Unknown Unknown Unknown Other
5 24e9.b3e5.dc3c to 24e9.b3e5.dc53 2.0 Ok
Mod Redundancy role Operating mode Redundancy status
3 Active Supervisor SSO Active
4 Standby Supervisor SSO Disabled
We connect the console on the module 4 and it's showing blank.
then we did the remove the module and put it back and it's same issue.
please find the below result:
* Welcome to Rom Monitor for WS-X45-SUP7-E System. *
* Copyright (c) 2008-2011 by Cisco Systems, Inc. *
* All rights reserved. *
Primary Rom Monitor Version 15.0(1r)SG5
CPU Rev: 2.2, Board Rev: 10, Board Type: 101, CPLD Moka Rev: 7.0x3718.0xb565
Chassis: WS-C4507R-E
Got Mac Address: 6c:20:56:d3:ea:ae
MAC Address : 6c-20-56-d3-ea-ae
Ip Address : Not set.
Netmask : Not set.
Gateway : Not set.
TftpServer : Not set.
***** The system will autoboot in 5 seconds *****
Type control-C to prevent autobooting.
******** The system will autoboot now ********
config-register = 0x2101
Autobooting using the first file from bootflash.....
loading image
Checking digital signature
bootflash:/cat4500e-universalk9.SPA.03.04.02.SG.151-2.SG2.bin: Digitally Signed Release Software with key version A
Rommon reg: 0x00004F80
Reset2Reg: 0x00000F00
Image load status: 0x00000000
Snowtrooper 155 controller 0x04506694..0x046B1A69 Size:0x0041DCD4 Program Done!
Linux version 2.6.24.4.2.70.k10 (krunyan@build-lnx-036) (gcc version 4.2.1 p7 (Cisco c4.2.1-p7)) #1 SMP Thu Sep 5 19:00:52 PDT 2013
Starting System Services
diagsk10-post version 5.1.4.0
prod: WS-X45-SUP7-E part: 73-14393-02 serial: XXXXXXX
Power-on-self-test for Module 4: WS-X45-SUP7-E
CPU Subsystem Tests ...
seeprom: Pass
Traffic: L3 Loopback ...
Test Results: Pass
Traffic: L2 Loopback ...
Test Results: Pass
post done
Exiting to ios...
Starting IOS Services
Platform Manager: acquire hwlock chassis()
Platform Manager: starting in standalone mode
8 Replies 8
Mark Elsen
 - Further check status of redundant supervisor with :
            show redundancy states
            show redundancy
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Redundant System Information :
Available system uptime = 2 days, 27 minutes
Switchovers system experienced = 0
Standby failures = 1
Last switchover reason = none
Hardware Mode = Duplex
Configured Redundancy Mode = Stateful Switchover
Operating Redundancy Mode = Stateful Switchover
Maintenance Mode = Disabled
Communications = Down Reason: Failure
Current Processor Information :
Active Location = slot 3
Current Software state = ACTIVE
Uptime in current state = 2 days, 26 minutes
Image Version = Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.04.02.SG RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 05-Sep-13 19:06 by prod
BOOT = bootflash:cat4500e-universalk9.SPA.03.04.02.SG.151-2.SG2.bin,1;
Configuration register = 0x2101
Peer (slot: 4) information is not available because it is in 'DISABLED' state
Looks like the secondary is not working properly
 M,
       Beauty and terror
      Just keep going
       No feeling is final
Please advise what could be the reason for this. Please advise.
Thank you.
 - Difficult to tell , could be hardware failure. My advise to re-seat the module (secondary supervisor), but before doing so have native console connected and watch the output when the module is inserted again. Check for errors , if any.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
We did the re seat the module and same blank screen is showing.
 - Then as Leo said , it is probably broken and you will have to have it replaced.
    M.
       Beauty and terror
      Just keep going
       No feeling is final
Leo Laohoo
Contact Cisco TAC and organize for an RMA.
