Connecting 2 Routers to 1 NM-4T1-IMA
smcline06
Working on a Cisco Lab and had a question. Would it be possable to connect 3 routers total using 3 NM-4T-IMA cards. Router 2 and Router 3 connecting to Router 1. Router 2 and 3 would only use 2 T1 lines each connecting them both to Router 1. Is this setup possable to do?
paolo bevilacqua
Yes. The card supports 4 IMA groups.
