Connecting "fast ethernet" to "ethernet" is not working!
Abdullah Net
Hey there,
I connected "FE 0/1" (cisco 1841) to "Ethernet 1/0" ( NM-4E module in 2651 router). Both interfaces' status are up but their line protocol is down.
I sat both their speed to 10Mbps and their duplux to full but no luck.
Is this because i am using a straight-throught cable? According to my understanding all cisco routers uses "Auto-Mdix" feature which eleminates the need for cross-over cables.
Abdul,
cadet alain
Auto mdix needs autonegotiation and not all devices or modules  support this feature.
Alain
7 Replies 7
Jon Marshall
Abdul
Most switches support that feature but not necessarily routers. If you were using a switch module in the router then it would probably support it but i'm not sure the onboard ports do.
Jon
cadet alain
Alain
HI Alain,
Another good peice of information, I was not really aware of this. I was under the impression that auto mdix works and is independent of speed/duplex settings. There definitely must be a reason behind auto mdix needing auto nego ON. If you could put some light on that too please
Umesh
although it is a very laconic explanation, it is explained here:
http://www.cisco.com/c/en/us/td/docs/routers/access/3200/hardware/guide/C3200ISR_HWRG/MR20fesm.pdf
Alain
Alain,
You are right. As it turns out, the "NM-4E" module is very very old and it lacks autonegotiation feature thus no auto-mdix.
I used cross-over cables and everything works fine now.
Abdul,
Dragan Ilic
Level 4
Level 4
Do you see something in log?
As I understand you have L2 issue - have you tried with static "half-duplex" on both sides?
HTH,
Dragan
HTH,
Dragan
Alain reminds us that auto mdix needs autonegotiation and Abdul tells us that he is hard coding the speed and duplex. I think that the simple thing is to try a crossover cable and see if the connection works with that.
Rick
Rick
