Connecting SMF fiber cable to a MMF port
r.subramani
I have a WS-X6816-10G-2T module with X2-10GB-SR modules. I will be getting a SMF hand off and the length of the termination is around 100 meters. (I will be getting another hand off for Inter-DC link for which I have X2-10GB-LR module). The question is can I connect this SMF hand off (short length) on the SR module? If so what is the penalty i.e. Signal Loss etc.
Ranganath
Reza Sharifi
No, with SR module, you can only use Multimode Fiber and not SMF.
turnera
Multimode equipment will not launch (inject) enough light into a  single-mode fiber since the light carrying core of this fiber is only 9  microns in diameter compared to 62.5 microns in diameter for multimode  fiber. It's like connecting 50 ohm coax cable to a 75 ohm coax cable. The impedence mismatch basically kills the signal and you could end up damaging equipment over time as a result.
Your only true course of action would be to get SM to MM converters and then you would be ok.
