Controller port error, Interface Gi3/0/28: Power Controller reports Short detected
Sandeep Verma
Level 2
Level 2
Hi All,
Recently deployed  Cisco Catalyst 3850-48P-E Stack Switch.  I am receiving a lot of syslog messages
''''Controller port error, Interface Gi3/0/28: Power Controller reports Short detected''''
Switch Software version : 03.03.02SE RELEASE SOFTWARE (fc2)
I have IP Phones and some access-points on these switches to supply power to. These messages have been populating recently only.
Can anyone kindly help with details of this issue and resolution as well ?
Many Thanks
Sandeep
Thanks Leo,
Here's the output
TDR test last run on: August 21 09:34:08
Interface Speed Local pair Pair length        Remote pair Pair status
Gi3/0/28  100M  Pair A     0    +/- 1  meters Pair A      Normal
                Pair B     0    +/- 1  meters Pair B      Normal
                Pair C     2    +/- 1  meters N/A         Open
                Pair D     23   +/- 1  meters N/A         Short
15 Replies 15
Leo Laohoo
Do this:
  1. Command:  test cable tdr interface Gi3/0/28;
  2. Wait for approximately 5 to 7 seconds;
  3. Command:  sh cable tdr interface Gi3/0/28; and
  4. Post the output to #3.
Thanks Leo,
Here's the output
Post deleted by author due to low rating by OP.
Thanks Leo.....!
Annnnd for that you rated my assistance a 4-star?????
Hi Leo,
Could you put the post again?
I have the same problem in my device  and I don´t know the cause of the issue.
Thanks in advance.
Regards.
Ivan.
Hi Ivan,
Open a new thread and send me a private message (PM) of the link.   I will be happy to help you.
I will not post the recommendation here because the OP has marked my original recommendation with a low rating.  If other people see my response with a low rating they might think that it's the incorrect or wrong course of action.
Hi Leo,
Would you be able to assist me with this same issue?  I am seeing a port with the following error:
Dec 19 09:11:39.405: %ILPOWER-3-CONTROLLER_PORT_ERR: Controller port error, Interface Gi3/0/4: Power Controller reports Short detected
Hi Charlie Jones,
This is are cosmetic bug CSCuo83872:
https://tools.cisco.com/bugsearch/bug/CSCuo83872
Please see attached pdf...
Hi Charlie,
I am happy to assist but please open a new thread.  I am not inclined to make any recommendation on this thread after the OP has rated my troubleshooting and diagnostics with a very pathetic score.
Anyone who gets to see my response with a low score will think of my post as BS.
If you are able to create a new thread and PM me the link, I will respond.
Hi Leo,
Thanks in advance.
Regards.
Ivan.
@Sandeep Verma
It's a bug man!
johnnylingo
Level 9
Level 9
I'm seeing this too on a 3650 switch with an AIR-LAP1142N-A-K9 attached.  Was working fine until a few days ago.
Does this indicate someone swapped in a bad cable, or could it be a false positive?  It's in a remote office 8,000 miles away, so visually inspecting this won't be easy.
#show cable-diagnostics tdr interface gigabitEthernet 1/0/1
TDR test last run on: June 17 12:06:37
Gi1/0/1   auto  Pair A     1    +/- 1  meters N/A         Short
                Pair B     1    +/- 1  meters N/A         Short/Crosstalk
                Pair C     0    +/- 1  meters N/A         Normal
                Pair D     0    +/- 1  meters N/A         Normal
The patch cable nearest the switch is bad, Johnny.  Get someone to replace the cable and chop it up.
