09-10-2019 08:55 AM
I need help with TFTP command syntax. What is wrong here?
image resides on solarwinds TFTP within C:\TFTP-Root. Devices are reachable too and TFTP service is active.
SWITCH#copy tftp: flash:
Address or name of remote host [x.x.x.x]?
Source filename [C:\TFTP-Root/AIR-CT5500-K9-8-5-151-0.aes]?
Destination filename [AIR-CT5500-K9-8-5-151-0.aes]?
Accessing tftp://x.x.x.x/C:\TFTP-Root/AIR-CT5500-K9-8-5-151-0.aes...
%Error opening tftp://x.x.x.x/C:\TFTP-Root/AIR-CT5500-K9-8-5-151-0.aes (Timed out)
Solved! Go to Solution.
09-10-2019 10:18 AM
Hi @davinci ,
Have you tried this?:
Source filename [C:\TFTP-Root/AIR-CT5500-K9-8-5-151-0.aes]? AIR-CT5500-K9-8-5-151-0.aes
09-10-2019 09:33 AM
09-10-2019 10:02 AM
09-10-2019 10:18 AM
Hi @davinci ,
09-10-2019 02:10 PM
09-10-2019 09:34 AM
Hmmm, I am a bit wary , with the switch platform handling these C:\ (backslash) denotions ; could you just make the root of the tftp server to the file location directory on Windows (so you only need to input the filename on the switch) ?
M,
09-10-2019 10:05 AM
yes, I have file in the C:\TFTP-Root directory. I have tried both ways with the switch copy tftp syntax, only specifying filename and also adding tftp directory
09-10-2019 10:00 AM
couple of steps to test before you copy.
1. from Switch you able to ping the TFTP Server IP address - yes - step 2 ( if not fix the changeability)
2. Step2 as @Mark Elsen suggested, the souse should be file name, the file should be in TFTP root folder. to copy
