Core Switch 6509-E Boot Problem
a_mohammedy
Community Member
i have a problem with Cisco Core Switch 6509-E in its boot as following:
rommon 3 > dir bootflash:
Initializing ATA monitor library...
Directory of bootflash:
2      74788836  -rw-     s72033-ipservicesk9_wan-mz.122-33.SXH5.bin
9132    33554432  -rw-     sea_log.dat
rommon 4 > boot bootflash:s72033-ipservicesk9_wan-mz.122-33.SXH5.bin
Please reset before booting
rommon 5 > reset
System Bootstrap, Version 8.5(4)
Copyright (c) 1994-2009 by cisco Systems, Inc.
Cat6k-Sup720/SP processor with 524288 Kbytes of main memory
rommon 1 > boot bootflash:s72033-ipservicesk9_wan-mz.122-33.SXH5.bin
Loading image, please wait ...
Self extracting the image... [OK]
Self decompressing the image : ################################################################################################################################################################ [OK]
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, s72033_sp Software (s72033_sp-IPSERVICESK9_WAN-M), Version 12.2(33)SXH5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Thu 16-Apr-09 19:33 by prod_rel_team
Image text-base: 0x40101328, data-base: 0x41C65B30
00:00:04: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
00:00:04: %PFREDUN-6-ACTIVE: Initializing as ACTIVE processor for this switch
00:00:06: %SYS-SP-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
00:00:04: %SYS-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
Firmware compiled 19-Feb-09 13:10 by integ Build [100]
00:00:06: %OIR-SP-6-CONSOLE: Changing console ownership to route processor
System Bootstrap, Version 12.2(17r)SX7, RELEASE SOFTWARE (fc1)
Copyright (c) 2009 by cisco Systems, Inc.
Cat6k-Sup720/RP platform with 524288 Kbytes of main memory
rommon 1 >
please advise ASAP
Chad Peterson
Your MSFC's config register is likely 0x0.
Once it gets to that point do 'set' and paste the output.
At that point you can boot it manually using the boot: command.
