CPU Load
rootadmin
Community Member
I am currently using a Cisco 3750 switch. Is there any commands in to bring down the CPU load in the switch.
Appreciate prompt reply. Thank you
Mansur
6 Replies 6
spremkumar
Level 11
Level 11
Hi Mansur
Can you post the output of show process cpu ?
This input will definetely help in identifying the process which hogs the cpu and the steps to be followed or implemented to bring it back to the permissible level..
regds
Have attached the CPU load file as requested.
Please go thru and kindly advise.
Thank you
Mansur
I know my answer is not specific to the 3750. But from the show file you posted, it's quite apparent that the STP process is taking up a lot of CPU time. Anyway, this link might help in your troubleshooting: http://www.cisco.com/en/US/customer/products/hw/switches/ps607/products_tech_note09186a0080094e78.shtml#STP
rootadmin
Community Member
Yeah..Got what u said...If I disable Spanning tree on all the switches..Would it help?
Mansur
Do not do that you are playing with fire if you disable spanning tree , this is what prevents you from having loops in your network.
ok....
