Creating a Port-Channel on New N9K system
scottcummins
Good Day Cisco Community
I have a Dell PowerEdge R420 Server with 2 Broadcom NetExtreme ethernet adapters both 1GB. The server is loaded with Windows 2008 R2 Server
I am trying to team the adapters using the Broadcom Advanced Control Suite software using LACP.
I have a 2 NEW Nexus 9504 core devices configured as a single core switch with two N9K-X9464PX blades each. I also have two NEXUS 2348TQ-E  set as FEX devices which expand my core device logically
My port channel is configured as such on BOTH Core systems
interface port-channel200
description **VV11 Server**
shutdown
switchport mode trunk
switchport trunk native vlan 999
switchport trunk allowed vlan 2-4094
spanning-tree port type edge trunk
spanning-tree bpduguard disable
flowcontrol send on
vpc 200
On both 9504's I have an ethernet port configured as such
interface Ethernet102/1/37
description **VV11 NIC 1**
When I try to add the port to Port Channel 200 I get the following no matter how I configure it
channel-group 200 mode on
command failed: port not compatible:[Emulated switch port type policy]
** You can use force option to override the port's parameters
** (e.g. "channel-group X force")
** Use "show port-channel compatibility-parameters" to get more information on failure.
I have created other port channels on here but they are used to connect other switches to the core, this a is the first server type device and it is not cooperating, can anyone assisty in why it will not allow me to add the ethernet ports to the port channel?
Mark Malone
You dont use the vpc bit when you already have it connected to a FEX
remove VPC 200 under the POand it will work or else use vpc and then use a standard port like e1/10 , non fex port
example from my NX FEXes with POs
interface port-channel26
description
no lacp suspend-individual
switchport trunk allowed vlan 1-1005,1226
!Command: show running-config interface Ethernet118/1/13
!Time: Tue Mar 10 17:28:22 2020
version 7.3(3)N1(1)
description
channel-group 26 mode active
Mark
That certainly helped in getting me a long way
So when I confiogured the second port on my other FEX, I go this error
gbnexus_9504-1(config-if)# channel-group 200 mode active
command failed: port not compatible:[Members in multiple FEX]
My config looks like this
description **VV11**
no shutdown
It gives me that error when trying to add the port on a different FEX  into the port channel
interface Ethernet101/1/42
description **VV11 NIC 2**
no shutdown
This error occurs because the port channel will only work with both links are either connected to the same logical or physical switch. This is why we use the vPC configuration because it makes 2 switches look like one switch to the downstream device. Your FEX are connected to the core switch but still look like separate switches.
You can try pairing the FEX to both of your core switches. The only issue is that both of them will load on both core switches so if you have FEX100 on one side and FEX101 on the other when you do a sh int st you will see FEX100 and FEX101 ports on both switches. This should solve your issue with port channel connections to the FEX.
