01-26-2019 09:08 AM - edited 03-08-2019 05:09 PM
Hello , i have a lab environment at home and i am running csr1000v's on an ESXi host and i have them connected to a physical switch, they see each other via CDP so that isn't a problem.
From R1 (CSR1000v) i have a sub interface g2.10 with dot1q 10 going to the switch which i configured an SVI interface vlan 10 in the same subnet as the sub interface on R1. And I cant get them to ping successfully. On the switch, R1's mac/arp entry shows up properly but from R1's perspective its ARP entry for the switch shows incomplete. Can anyone give me advice on how to get this going or what im missing? I followed an INE video exactly and I cant get it to work. Not sure why I cant get the pings going.
Thanks.
01-26-2019 09:31 AM
post the configs of both devices...
01-26-2019 10:29 AM
Okay here are the configs and ARP debugs for devices switch 2 (10.0.0.14/24) and router 1's Gig2.10 (10.0.0.20/24). I omitted items so its not so much to go through but here is the main config. Just to clarify they see each other via CDP but ARP entry on R1 shows incomplete thus ping fails.
hostname R1
no ip domain lookup
ipv6 unicast-routing
username admin privilege 15 password 0 cisco
redundancy
mode none
cdp run
interface GigabitEthernet2
no ip address
negotiation auto
cdp enable
interface GigabitEthernet2.10
encapsulation dot1Q 10
ip address 10.0.0.20 255.255.255.0
cdp enable
virtual-service csr_mgmt
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
end
R1#ping 10.0.0.14
Sending 5, 100-byte ICMP Echos to 10.0.0.14, timeout is 2 seconds:
IP ARP: creating incomplete entry for IP address: 10.0.0.14 interface GigabitEthernet2.10
IP ARP: sent req src 10.0.0.20 000c.2970.f695,
dst 10.0.0.14 0000.0000.0000 GigabitEthernet2.10
IP ARP rep filtered src 10.0.0.14 0021.55ef.d041, dst 10.0.0.20 000c.2970.f695 wrong cable, interface GigabitEthernet2.
RARP: Rcvd RARP req for 000c.295e.b333
IP ARP throttled out the ARP Request for 10.0.0.14
RARP: Rcvd RARP req for 000c.29f0.b31d.
RARP: Rcvd RARP req for 000c.2961.3fd1
RARP: Rcvd RARP req for 000c.291d.49bf.
RARP: Rcvd RARP req for 000c.2961.3fe5
RARP: Rcvd RARP req for 000c.2919.66f6
RARP: Rcvd RARP req for 000c.2919.660a
Success rate is 0 percent (0/5)
Switch 2
SW2#sh run brie
Building configuration..
hostname SW2
boot-start-marker
boot-end-marker
logging buffered warnings
no aaa new-model
switch 1 provision ws-c3750e-48pd
system mtu routing 1500
ip routing
no ip cef optimize neighbor resolution
no ip domain-lookup
vtp domain ABC
vtp mode transparent
spanning-tree mode pvst
spanning-tree vlan 1-4094 priority 16384
vlan internal allocation policy ascending
vlan 10
interface FastEthernet0
no ip address
no ip route-cache
interface GigabitEthernet1/0/48
switchport mode trunk
interface Vlan1
no ip address
interface Vlan10
ip address 10.0.0.14 255.255.255.0
ip http server
line con 0
logging synchronous
line vty 0 4
login
line vty 5 15
login
mac address-table notification change
mac address-table notification mac-move
mac address-table static 0c4d.e9d4.bf10 vlan 1 interface GigabitEthernet1/0/1
end
*Switch 2's ARP debug while R1 tried to ping it
SW2#
IP ARP: arp_process_request: 10.0.0.20, hw: 000c.2970.f695; rc: 3
IP ARP: rcvd req src 10.0.0.20 000c.2970.f695, dst 10.0.0.14 Vlan10
IP ARP: ignored gratuitous arp src 10.0.0.20 000c.2970.f695, dst 10.0.0.14 0021.55ef.d041, interface Vlan10
IP ARP: creating entry for IP address: 10.0.0.20, hw: 000c.2970.f695
IP ARP: sent rep src 10.0.0.14 0021.55ef.d041,
dst 10.0.0.20 000c.2970.f695 Vlan10
SW2#
SW2#
SW2#
SW2#
RARP: Rcvd RARP req for 000c.2970.f695
01-28-2019 07:03 AM
I have read at least one other thread with this specific issue when it comes to connecting physical hardware to the CSR1000v's.
Any ideas? I posted the configs hope that helps.
01-26-2019 09:34 AM
adding to otehr post, can you check the interface security config, (Configuring promiscuous mode)
01-26-2019 10:31 AM
Hi thanks for the link. I checked it out and I enabled promiscuous mode and it still didnt help.
01-26-2019 10:45 AM
Can you post vSwitch screen shot how you have tagged vlans against interfaces.
01-26-2019 12:12 PM
Here is my vSwitch. All CSR's are connected to it and the vmnic1 is bound to my NIC going to the physical 3750. all vlans are allowed
