Default route redistributed
adibenedetto18
Frequent Visitor
Frequent Visitor
I was wondering if there is a way to remove a redistributed default route from a branch router’s routing table automatically, when one router goes down. Example: R1 and R2 redistrubte a default route 0.0.0.0 to R3. If R1 goes down that default route is not functional but, in router R3 routing table it still exists. In R3 if I do a clear ip route the route is removed because R1 is still down. Essentially I want the function of clear ip route to initiate automatically.
viswamin
can be acheived using Cisco's IP SLA configuration.
Hope this link helps
http://www.firewall.cx/cisco-technical-knowledgebase/cisco-routers/813-cisco-router-ipsla-basic.html
-Vijay
