DFE Mismatch
I am installing a new supervisor 720 to my 6509 siwtch but I am getting the following error:
00:01:33: %C6KENV-SP-2-DFCMISMATCH: Module 9 DFC incompatible with Supervisor DFC. Power denied
Here is the output of the show module command: (File Attached)
Is ths something I can fix upgrading the IOS of the supervisor or do I need to remove the DFC module on the card?
Jon Marshall
Hi Vicente
The suprevisor 720 does not support a DFC (WS-F6K-DFC) card. It supports the DFC3A, DFC3B & DFC3BXL cards.
Attached is a link to Cisco doc with more details
http://www.cisco.com/en/US/products/hw/switches/ps708/prod_module_installation_guide09186a0080163594.html#wp59534
Jon
glen.grant
Probably running into this , hopefully this is readable . Click on link for explanation .,
WS-F6K-DFC3BXL
Minimum Software Version
WS-F6K-DFC3BXL
With a Supervisor Engine 720 but without a DFC3, WS-X6516-GBIC switching module hardware revisions 5.0 through 5.4 operate in bus mode.
See external field notice 24494 for more information about Supervisor Engine 720 and a DFC3 on WS-X6516-GBIC switching modules:
http://www.cisco.com/warp/public/770/fn24494.shtml
Jon Marshall
Hi Vicente
Jon
Hi Jon,
Thanks for the link, I need to remove the DFC module from this card in order to make it work with my new supervisor...
Vicente
