Strange problem with dialer persistent on multiple dialer interfaces -
jfletcher
I've come across some strange router behaviour to do with dialer persistant...
One of our customers requires the following solution:-
A router supporting a standard ADSL connection, but with an audio modem backup - so that connectivity can be maintained via an analog dialup if ADSL fails.
The hardware setup is an 837, running the latest available IOS 12.4(13b), with a USR robotics modem sharing the ADSL line (via a splitter) and plugged into the router console port.
The configuration uses dialer persistant on two interfaces and relies on "backup interface" to switch the backup connection on & off.
The problem.
a) Starting from ADSL up - all fine - can ping outside world.
b) Pull ADSL cable from router - audio modem dials out to ISP & reconnects - all fine.
c) Reconnect ADSL cable to router - audio modem disconnects - ADSL reconnects - all fine.
d) Pull ADSL cable from router 2nd time - audio modem **FAILS** to dial out -
connection stays down permanently.
This is totally repeatable upon router reboot.
Shut/no shut backup interface - no effect
Power cycle audio modem - no effect
However,
CONF T,
Interface Dialer2,
no persistant dialer,
persistant dialer
--> **fixes** problem temporarily ??? (At least for one DSL failure cycle)
Is this an IOS issue - or am I missing something here ?
The fact that toggling the persistant dialer command on/off fixes the problem - does suggest to me that the issue does not lie with the audio modem.
Thanks in advance,
Julian
Please find attached config & debug dialer events for more detail.
ohassairi
Level 5
Level 5
i can't answer your question but why you don't use 2 default routes with different metrics:
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 0.0.0.0 0.0.0.0 Dialer2 50
anharring
Is the Modem still busy from the previous call? - time out 120 seconds?
Does the ISP check for multiple MAC addresses on the same line - as you said you use the same line with a splitter?
Probably need to know what the Modem is doing:
#show modem summary
#debug dialer packets
#debug dialer events
#debug chat
#debug modem
PPP debugs, even though your not getting as far as PPP negotiation.
#debug ppp negotiation
#debug ppp authentication
#debug PPP events
Modem support and chat scripts:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1828/products_command_reference_chapter09186a00800ca53e.html
Configuring and Troubleshooting modems:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_command_reference_chapter09186a00800ca653.html
I turned on the additional debugs, as requested - please see attached file.
(Its from a different router with identical hardware/slightly different IP - but behaviour is identical)
I'm running PPPoATM, so no mac addresses are involved here.
Looking at the debug, the async interface is never invoked 2nd time around.
Just want to do a sanity check here before I raise a TAC case.
Julian
