11-04-2005 01:49 PM - edited 03-05-2019 11:41 AM
I need to configure an etherchannel and was wondering if either lacp or pagp have to be configured in conjunction with it?
Thanks.
11-04-2005 02:13 PM
you do not need PAgP (Cisco-proprietary) or LACP (IEEE 802.3ad standard), when you set your channel to:
channel-group 1 mode on
PAgP and LACP are disabled.
Here are the available channel modes:
On
--> PAgP and LACP disabled (no negotiation)
Desirable
--> Actively negotiate PAgP
Auto
--> Passively listen for PAgP
Active
--> Actively negotiate LACP
Passive
--> Passively listen for LACP
The following combinations for both sides will result in successfully establishing the channel:
On -- On
Desirable -- Desirable
Desirable -- Auto
Active -- Active
Active -- Passive
HTH,
GP
11-04-2005 02:51 PM
If you have cisco on both sides just run pagp with both sides set to desirable. If you have mixed gear then you need to runn lacp . The general cisco recomendation is to set both sides as desirable.
11-07-2005 01:03 PM
Thanks for everybody's responses. What is the upside of using or downside of not using pagp/lacp.
Thanks again
11-08-2005 12:25 AM
the main difference is that PAgP is Cisco-proprietary, while LACP is IEEE defined (802.3ad), AFAIK, the protocols are quite similiar, with a few exceptions, e.g. LACP does not support half-duplex links.
HTH,
GP
11-08-2005 07:40 AM
Thanks. I guess what I am really trying to understand is the rational of creating an etherchannel without either PAgP or LACP. Would would be the downside? Thanks.
11-08-2005 12:08 PM
I guess it can be compared to duplex and speed autonegotiatin in Ethernet environments. Setting speed and duplex to a fixed value on both sides is preferable when you are sure that either side will never be used for anything else than the device it is connected to. So, I would always disable negotiation if possible...
HTH,
GP
11-08-2005 03:26 PM
Just thought I'd throw in another bit of info... if you're using 3750s and want to do FEC to two switches in a stack you need to manually configure it using the 'channel-group 1 mode on' command on the ports as opposed to using PAgP or LACP.
Which is handy sometimes.
Aaron
